Go to Post IF teams did NOT READ THE FIRST MANUAL AND Q&A SITE, it is not FIRST's fault, it is the TEAM'S fault - sburro [more]
View Poll Results: What are you using?
Intake ElToro 19 10.67%
Intake Wheels 114 64.04%
Intake Other 34 19.10%
Shooter Catapult 96 53.93%
Shooter Wheels 8 4.49%
Shooter Kicking 17 9.55%
Shooter 1114 in 2008 22 12.36%
Shooter Other 29 16.29%
Not Picking Up 6 3.37%
Not Shooting 13 7.30%
Multiple Choice Poll. Voters: 178. You may not vote on this poll
Unread 16-01-2014, 18:55
blazeflipper's Avatar
blazeflipper blazeflipper is offline
AKA: Brandon Kaas
FRC #3184 (Burnsville Blaze Robotics)
blazeflipper is an unknown quantity at this point
Re: New Poll on What Are You Using
My team has been building a pneumatic shooter the past couple days. We had been running into the problem of not enough air to the cylinders to get the height needed. Today we added air tanks after the solenoids and lowered the mounting point for the two four inch long pistons and we had enough power to break a 2 by 4 in half when we dry fired. If your team is thinking about pneumatic I would highly recommend it, if you set it up correctly it has more power than you could ever need.
Unread 17-01-2014, 03:12
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
We're going with a winch pulled launcher that has a seat for the ball. The seat sits on top of a track, and the seat gets pulled back by a ratcheting winch, and when released, the seat moves along the track and stops abruptly at the end, therefore launching the ball. It's basically a ball puncher without the ball in front, but on top, if that makes any sense.
The track is on a pivot to allow for loading from the back, and aiming.
Just imagine an aircraft carrier catapult, or a crossbow, and you'll probably get what I mean.
The attachment shows a pic of an aircraft carrier catapult, and it follows the same idea.
This design was actually inspired by the linear human catapult I saw in the "Wipeout Zone" obstacle course on the ABC show "Wipeout."
Inspiration comes from the least expected places, don't they?
Unread 17-01-2014, 05:34
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
This was one of the three main designs we pursued and prototyped on 2395 but we had difficulty getting the rig to work properly.
So we have opted to be like everyone else and build a catapult, because the prototype showed the most promise and the design was the easiest for us to build (not saying that's a bad thing).
Sometimes good engineering requires following the crowd.
Though we have a few ideas that might set it apart from the others of course
As for the intake, we're not going with wheels, or the "el toro", but rather an older Dr. Joe inspired intake which is also going to have a Ninja Munkees twist
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 17-01-2014, 12:51
bEdhEd's Avatar
Our team is the opposite, I guess. Our puncher works better than the catapults we've tried.
Unread 17-01-2014, 13:03
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Because your puncher has a fairly large surface area contacting the ball. That's the trick I think a lot of puncher prototypes are missing.
Unread 17-01-2014, 23:08
bEdhEd's Avatar
I think you're right on that. The smaller surface areas put more energy into deforming the ball at a smaller point, rather than spreading it out on a larger surface for a more efficient push that deforms the ball less and more evenly, thus dedicating more energy to the launch.
