Our team is trying to make a catapult using a pneumatic piston as the spring. The piston would be closed off completely on one end and a pressure gauge and release valve on the other. Concern has risen among some of the team that this is not legal. Can anyone say for sure if this allowed or not?
Any help or advice would be greatly appreciated, Thank You. |
Re: Is this legal?
I cannot find anything in the rules against it; in fact R81-D mentions use of the KoP vent plug.
Re: Is this legal?
Pay attention to R78-R80, if you add any pressure to the cylinder to pre-charge it you will need to use a robot controlled compressor that matches the set up in those rules. Also, with the system you described, according to the rules you will need a gauge and a regulator(even though you wouldn't use it). You would also be limited to 60 psi and if you compress the air in the cylinder you will have to do the math to find out if you will peak over 60psi when compressed.
Rules can be tough, I can't say for sure that all of these would be enforced in the full extent for your system, but I would think they should. It is really awful to get to a competition and find out something isn't legal. It's even worse to find out it is legal right after you tear your "illegal system" all out and replace it (oh 2012, you were cruel to us...) Last edited by MrBasse : 16-01-2014 at 19:39. Reason: Ilegal is different than an ill eagle... |
Re: Is this legal?
The vent plug is also known as the "dump valve". Also note that you're asking in the wrong place--try the official Q&A. So let's see if I understand the setup of the cylinder-as-spring. One end of the cylinder is plugged--nothing in, nothing out. The other has a gauge and a release of some form (I would suspect a solenoid would be better....) Now, per Q34 on Q&A, a quick release is illegal. You also have to be aware of the 60 psi working air limit (Q129/R82). A regulator might work, but I'd guess you'd be losing air quite a bit. To be honest, I would have to see the setup to pass it or fail it, but I'd be leaning towards failing right now. If I might make a suggestion, try a closed-loop gas shock, or full pneumatics. |
Re: Is this legal?
It seems that Q129 on the FRC Q&A would make this illegal IF (and only if) the pressure was to exceed 60 PSI.
However, it may be possible to find a gas spring (like they use to hold up the rear hatch on an SUV) to do that; it is not a pneumatic component. Quote:
