Go to Post If all else fails, just ask the judges to turn off the gravity! :D - [more]
Unread 16-01-2014, 19:38
Re: Mecanum forward rotation error
Originally Posted by mattachew12 View Post
Update: We've isolated the problem to the lights on the sidecar. Something is breaking the 6V light. Every time this disable problem happens the sidecar's 6V light is off. When we switched a new sidecar in, the three lights turned on and we got our full rotation functionality back, but today we just broke the light again by rotating too much apparently and somehow overloaded the sidecar. It auto-disabled again and now the 6V light won't come on again. What I don't get is jaguars shouldn't be affected by the 6V since their PWMs use 5V.
What breaks a sidecar's 6V capability?
The only thing that uses 6v is servos (when the jumper is installed next to the PWM). I suspect that you are not getting power to the digital sidecar. Did you remove the DB-37 cable and look at the LEDs like was suggested earlier?
