Go to Post Science and Technology is like the tide in the ocean, it raises all ships together, whether they're an engineering ship or a manual labor ship. - Doc Wu [more]
Unread 16-01-2014, 19:48
mattachew12 mattachew12 is offline
FRC #3597
mattachew12 is an unknown quantity at this point
Re: Mecanum forward rotation error
Originally Posted by Joe Ross View Post
The only thing that uses 6v is servos (when the jumper is installed next to the PWM). I suspect that you are not getting power to the digital sidecar. Did you remove the DB-37 cable and look at the LEDs like was suggested earlier?
When we take off the cable the 5V and RSL lights turn off. What should happen?
Error 404-Signature Not Found
