Go to Post At least I can appreciate the humor in this LOLCODE; it isn't funny when our our robot goes backwards in hybrid mode - sgreco [more]
Unread 16-01-2014, 20:27
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
Sonar not responding
We are trying to use the HC-SR04 Ultrasonic range finder. However, it is not working. Our wiring successfully wires the two signals to separate ports. Our code is attached.
Unread 16-01-2014, 20:46
Re: Sonar not responding
What ultrasonic rangefinder are you using?
Unread 17-01-2014, 20:24
AKA: Ari Falkner
FRC #3024
The HC-SR04.
Unread 19-01-2014, 08:48
AKA: Brad
#0190 ( Gompei and the Herd)
I believe that your rangefinder is the same design as the Daventech SRF04 model and works with WPILib as described here:
http://wpilib.screenstepslive.com/s/...asonic-sensors
Be careful, it has two connections:
  1. Echo pulse output: Causes the sensor to send an ultrasonic "ping"
  2. Trigger pulse input: listens for the echo to return
Be sure to connect it as described in the documentation.
Brad Miller
Robotics Resource Center
