Go to Post Mentors can't get tired, it says so in the manual. SENIOR mentors, therefore, must have a different manual! - KathieK [more]
Unread 16-01-2014, 21:37
FS Robotics FS Robotics is offline
FRC #5119
FS Robotics is an unknown quantity at this point
Jaguars and Talons
Are Jaguars and Talons compatible? Nothing that I have found shows that there are any key differences that would create problems if we used both on the same bot, but I'm curious if anyone has insight on this. Thanks!
Unread 16-01-2014, 21:38
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Jaguars and Talons
Depends how you want to use them.
-Mixing in the drivetrain - NO
-Elsewhere - Sure, unless the two motors are sharing the same load
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 16-01-2014, 21:50
Why not?
Why not?
Unread 16-01-2014, 22:07
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Why not?
Why not?
Well Ether,
I would suspect because the motor curves are different??
What's the exact explanation or correction?
Unread 16-01-2014, 22:14
yash101 yash101 is offline
AKA: null
Well Ether,
He means the controller curve. A Victor has a different curve from the Talon, which has a different curve from the Jaguar. Mix up the motor controllers and some motors are not spinning as fast as others, causing strafing in the drivetrain, or abrasion in a motor set, when a motor needs to fight the less power being received by a different motor. In real life, while these issues are quite minimal because a lot of work is done to make the curve more linear, It isn't what you want for precision operation!
The code is something that hasn't been discussed too much. Using the same motor controller for at least a specific component will ensure that the code stays cleaner and easier to understand. You don't want to look at programming jargon, where half a subsystem runs code for a Victor/Talon, and the other half runs the Jaguars. That just becomes very messy and can be hard to understand.
Unread 16-01-2014, 22:29
It's OK to combine motors with different motor curves.
For example, a CIM and a mini-CIM on the same gearbox.
Unread 16-01-2014, 22:30
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
My bad, as Yash 101 said, I meant controller curves
Unread 16-01-2014, 22:31
So why is that not OK,if it's OK to combine motors with different curves?
Unread 16-01-2014, 22:36
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Hmmm good point. I just always assumed it was just bad practice.
SO does it have much effect???
Unread 16-01-2014, 22:43
If you're trying to do closed-loop control there might be situations where it might be preferable to match the controllers.
Hey CD, any teams out there who used 1 Jag and 1 Talon for each 2-CIM gearbox on each side ?
Unread 17-01-2014, 13:38
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
Slightly different but same principal I guess: This year we had 3 884 victors from vex and then 1 884 from Ifi and there was a significant difference in our drive train as it would turn ever slightly to the side. However, those were not jaguars or talons so not sure about that combination of those two. Also, all of the victors were tested beforehand and worked well. Just figured this would help a bit even if it wasn't what you were looking for exactly
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 17-01-2014, 13:51
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Well........IFI owns VEXPro so essentially it was just an older 884 and a newer one. There was a year there where they rebranded their stuff. So accordingly, we have IFI spikes and VexPro Spikes
Unread 17-01-2014, 14:13
Unless you swapped the two left-side Vics with the two right-side ones and observed that the problem switched sides, you can't conclude that the turning was caused by a difference in the Vics.
Unread 17-01-2014, 15:49
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
You could run unmatched tires on your car but I would not recommend it.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 17-01-2014, 16:44
Not analogous.
