Go to Post Their robot moves so fast that it changes colour due to the Dopler Effect. By rapidly alternating between driving away from the viewer (Redshift) and driving toward the viewer (Blueshift), they can make the viewer see it in their traditional purple colour. - philso [more]
Unread 17-01-2014, 11:37
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
powder coating after assembly??
So our drive is all machined and not together, we just a local shop to powder coat stuff for us.
So we are split as to whether or not we should have them powder cost each part separated or after assembly. They have huge ovens and our drive is 28"x 28"x 2"
thanks
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 17-01-2014, 11:41
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: powder coating after assembly??
thanks
You want to take the risk that if you remove something from it there's no powder coating on the hidden surfaces?
You welded the frame and are prepared to grind off the powder coating to fix broken joints?
You don't mind the powder coat sticking to everything?
You hope corrosion won't form between 2 parts of metal stuck together in close proximity?
Generally I don't powder coat my vehicles with the car assembled.
I may powder coat the frame but it's welded and after assembly of the car if the frame breaks the repair will be hard anyway.
So grinding off my powder coat might be the easy part.
Unread 17-01-2014, 11:44
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
So our drive is all machined and not together, we just got a local shop to powder coat stuff for us.
So we are split as to whether or not we should have them powder coat each part separated or after assembly. They have huge ovens and our drive is 28"x 28"x 2"
thanks
We have each part powder coated.
This way we don't have to worry about nuts and bolts getting baked to the frame.
Your choice though
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 17-01-2014, 11:49
AdamHeard's Avatar
Lead Mentor
For our gusset/rivet and sometimes welded frames we powder the entire assembly. Much easier that way.
Unread 17-01-2014, 12:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We rivet, then weld, then powder coat our frames.
Brandon Holley's Avatar
If you are confident a sub-frame assembly of some sort shouldn't have to come apart, the fewer number of indivudal assemblies, the better.
We powdercoat in our own shop, and we will do all of our gusseted/welded frames as one piece as it is much easier to handle than several individual parts.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
