Go to Post If that due diligence shows that a real need for action exists, *then* grab the pitchforks, and light the torches. - gblake [more]
Unread 17-01-2014, 13:55
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Team Update 1-17-2014
Administrative Manual:
6.10 ENTREPRENEURSHIP AWARD sponsored by Kleiner, Perkins, Caufield & Byers
6.10.2 Guidelines
EXECUTIVE SUMMARY
ORGANIZATIONAL STRUCTURE: Please detail how the team is structured to 1) Raise funds; 2) Ensure funds are properly spent; 3) Find and engage sponsors; 4) Recruit team members/mentors for current & future seasons; 5) Ensure FIRST principles remain core to the team’s efforts. Uploading an image of your team organizational chart below, will also satisfy this requirement.
(1600 characters allowed, including spaces and punctuation. Graphic image allowed in addition to or as an alternative to text - upload 5” x 4” 100 dpi resolution images that end in .JPG or .GIF)
FINANCIAL STATEMENT: Please include information on team finances (include financial statement detailing income and expenditures). Uploading an image of your team financial plan below, will also satisfy this requirement.
(1600 characters allowed, including spaces and punctuation. Graphic image allowed in addition to or as an alternative to text- upload 5” x 4” 100 dpi resolution images that end in .JPG or .GIF)
Game Manual:
Game Manual
Section 2.2.4: VISION TARGETS
The retro-reflective material on the dynamic VISION TARGET is nominally 3¾ in. from the FIELD-side surface of the ALLIANCE WALL polycarbonate sheet above the LOW GOAL.
Section 3.2.3: General Rules
G12
An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION:
“carrying” (moving while supporting BALLS in or on the ROBOT),
“herding” (repeated pushing or bumping),
“launching” (impelling BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT),
“trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Violation: TECHNICAL FOUL per instance. If extended, another TECHNICAL FOUL. If strategic, RED CARD for the ALLIANCE.
Section 4.6: BUMPER Rules
R26
In Team Update 2014-01-14:
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-10). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap between the backing material and the frame
  • must not be greater than ¼ in. deep or
  • the BUMPER must be backed by the FRAME PERIMETER at least every 8 in wide.
In Manual:
  • must not be greater than ¼ in. deep, and (change to “or” per last TU)
  • not more than 8 in. wide.
Section 5.1: Overview
In the event where order placement of ROBOTS matters to either or both ALLIANCES, the ALLIANCE must notify the Head Referee during setup for that MATCH. Upon notification, the Head Referee will require ALLIANCES to place their ROBOTS per the following protocol:
Qualification MATCHES
Blue GOALIE (if in use)
Red GOALIE (if in use)
Blue ROBOTS in the White ZONE
Red ROBOTS in the White ZONE
Elimination MATCHES
Lower seed GOALIE (if in use)
Higher seed GOALIE (if in use)
Lower seed ROBOTS in the White ZONE
Higher seed ROBOTS in the White ZONE
Section 6: Glossary
POSSESS: (for a ROBOT) to carry (move while supporting BALLS in or on the ROBOT), herd (repeated pushing or bumping), launch (impel BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT), or trap (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them) a BALL.
Unread 17-01-2014, 13:59
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Team Update 1-17-2014
That really opens up some defensive play.
Unread 17-01-2014, 14:03
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Possessing the opponents ball is still prohibited. Care to explain your thoughts?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 17-01-2014, 14:05
AdamHeard's Avatar
Lead Mentor
Hit it.
Unread 17-01-2014, 14:06
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
The new standard for ground-only (no manipulator) POSSESSION is herding (repeated pushing or bumping) and trapping. If you drive by, and hit the opponents ball away, then drive away, you're good. Basically, if you aren't in control of it after you hit it (once) away, you should be penalty free.
Flywheel Police
Hit it.
Exactly, you can now plow into their ball once and drive away.
Unread 17-01-2014, 14:07
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I believe the concern was that attempting to deflect an opponents ball (ie a single bump on the ball that sent it in a new, likely desired, direction) could be considered launching and earn a penalty via g12. This update makes it clear that getting in the way like that is legal and does not incur a penalty.
2016: Lake Superior WFFA
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I have a question on the bumper rule. Do robot wheels qualify as part of the "frame" for the purposes of backing the bumper less than 1/4" away from the plywood? Can the wheels be the "frame" members that break up the span between the ends into <8" long portions, for the purposes of satisfying the bumper rules.
Unread 17-01-2014, 14:11
Per R2,
The ROBOT must have a FRAME PERIMETER, contained within the BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT. Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the FRAME PERIMETER.
Wheels would not qualify as fixed, non-articulated structural elements. If I were inspecting your robot, I would not count the wheels as sufficient backing for the bumpers, but as always the only definitive answer you can get is the Q&A.
Unread 17-01-2014, 14:28
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
So, if you catch an opponents ball (by mistake - not through any intent on either alliance's part), then you incur a penalty if you keep it, and you incur a penalty if you kick it out of your robot?
Seems to provide a powerful deterrent to an open-topped passive catching design.
Do I have this correct?
- Mr. Van
Coach, Robodox
Unread 17-01-2014, 14:29
Flywheel Police
- Mr. Van
Coach, Robodox
That's the way I always understood the rule, and the update doesn't seem to have changed that.
Unread 17-01-2014, 14:35
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
I think this update further clarifies POSSESSION as:
So, now there is no doubt that if an opponent ball accidentally landed in your robot and you use a mechanism to remove the ball, you can be penalized.
Unread 17-01-2014, 14:40
Flywheel Police
Technically there is still a loop hole. If you catch the opposing alliance's ball and don't move you have not technically possessed the ball according to the definition.
Unread 17-01-2014, 14:52
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Incorrect. You are "Trapping" the ball
Unread 17-01-2014, 15:00
#0599 (Robo-Dox)
So, if an opponent's ball lands in your robot, the only way to not incur a penalty is to not move?
It seems to me then that "catching" requires some sort of active mechanism that will NOT work unless you really want it to, or you must make a covered top for your robot so that a ball can't fall into it at all. For example, all of the "3-day" robots are very vulnerable to opponent's balls landing in them.
I thought that the Truss Toss & Catch was one of the best elements in the game, but now instead of designing something that will trap a flying ball, we've got to make sure we DON'T catch an errant bounce from our opponent.
I hope this gets fixed quickly!
- Mr. Van
Coach, Robodox
