Go to Post That makes it a winning move to, well, win. - EricH [more]
Unread 17-01-2014, 15:05
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Team Update 1-17-2014
Nothing needs to be "fixed"...
If your robot is designed to catch at any time, that is your design decision, and you need to stay away from the opponent's balls. If you want to be in the mix pushing people around, especially when your opponent is trying to TRUSS/CATCH, your robot better not be able to catch balls.
Unread 17-01-2014, 15:15
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Originally Posted by BBray_T1296 View Post
Incorrect. You are "Trapping" the ball
Wrong. If an opponents ball lands in your robot and you stop moving and you were not purposefully catching the ball, then you are not shielding the ball purposefully from the other alliance.
If the other alliance's ball happens to land inside your robot and it was inadvertent, if you stop moving immediately then it would seem that you would not be penalized.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 17-01-2014, 15:24
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Agreed, I would not consider a ball inside of your robot as trapping. But, I would also not consider this the intent, or even a strategy that should be implemented in any way.
Unread 17-01-2014, 15:25
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
“launching” (impelling BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT)
The only thing this update was trying to change/clarify is the fact that a single hit of the ball with the bumpers or any other static part of the robot is not considered possession. A bot that unintentionally catches a ball is affected as it always was.
I think this change was necessary because there would have been controversy on every call/no call made in regards to a robot contacting an opposing alliance's ball. I just hope strategically this doesn't hurt the game too much. Assisting is going to be significantly harder now, at least at regionals, because not only does an alliance bot need to do more to gain possession, but a defending bot can literally seek to hit the ball now.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 17-01-2014, 15:31
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
As the rules are written, I believe you're right.
That being said, I highly doubt the call will be this cut and dry. If you catch a ball, put your hands up in the air, and make it clear to the refs that you did not intend to do it, and you don't want to actively release it, then what happens? Do you sit there for the rest of the match as a black hole? Does the Head Ref make the call to put another ball into play as if your robot died with a ball in it? It's an interesting (and annoying) situation to think about for sure.
If anything, there needs to be some sort of grace period for an unintentional catch, where a machine is given some reasonable amount of time (say 5-10 seconds) to get the ball out of their robot without being penalized - although even that isn't that simple. On paper, there are certain situations where it may make sense for a team to build a human load only machine, where the only method of releasing the ball they have is a truss or goal shot - at that point, does them shooting the ball (where ever) turn an accident into a strategic advantage? Teams with intakes or other methods of doing a 'slow' and or 'controlled' ball release wouldn't really be an issue here, since they could essentially drop the ball where it was caught and carry on with the match.
-Dustin Benedict
Unread 17-01-2014, 15:32
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Defense is simple. Stop trying to lawyer the rules. Play the robot not the ball.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 17-01-2014, 15:34
AdamHeard's Avatar
Lead Mentor
Yeah play the robot.
Flywheel Police
With this change it makes it clear that you are allowed to play the ball though.
Unread 17-01-2014, 15:37
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
What if you are the team trying to TRUSS/CATCH?
Is catching now not only a design challenge, but a high risk strategy? I don't think that the intent of the game was to deter teams from catching balls. This seems to be equivalent to a rule that stated "a high goal shot that hits the player station wall but does not enter the goal will be a penalty". If this were a rule, would you take the risk hope you never miss a shot?
Is anyone going to design a catching robot knowing that any random bouncing opponent ball could potentially cause a penalty? I know that this change (that you can't eject an opponent's ball from your robot without a penalty) is causing us to question the validity of a catch at all...
- Mr. Van
PS - If making "assists" is now more difficult (because an opponent is able to simply bump the ball away from you as you try to pass from one robot to another), then this
makes me fear that this game may dissolve into most robots playing defense against each other and traditionally strong teams running the field by themselves bypassing any assists (inbound, truss, high goal - 20 pts/cycle - repeat - while everyone else is in shoving matches).
AKA: Ryan Guinn
From G12:
A BALL that becomes unintentionally lodged on a ROBOT will be considered POSSESSED by the ROBOT. It is important to design your ROBOT so that it is impossible to inadvertently or intentionally POSSESS an opponent’s BALL.
Since possession, specifically trapping, can be defined as overt isolation, you would be penalized for inadvertently catching the ball and stopping.
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
I'd recommend taking a really close look at the definition of trapping:
“trapping” (overt isolation OR holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them). -emphasis on the first OR is mine
The way I read that rule, overt isolation of the opponents ball is trapping; and catching it and leaving it inside your robot would be pretty "overt isolation".
Just my $0.02
Unread 17-01-2014, 15:39
Flywheel Police
Just my $0.02
I stand corrected. I still thought it would have been a penalty anyway since that is the intent of the rule in the first place.
Unread 17-01-2014, 15:41
AKA: Josh P.
- Mr. Van
PS - I'm beginning to fear that this game may dissolve into most robots playing defense against each other and traditionally strong teams running the field by themselves bypassing any assists (inbound, truss, high goal - 20 pts/cycle - repeat - while everyone else is in shoving matches).
I'd argue that if your robot is in a configuration in such that it could catch a ball, the burden is on you to be aware of where both your and the opponent's ball is and make sure you don't catch the opponent's ball. These aren't "random bouncing balls", there is one ball of each color to keep track of.
Unread 17-01-2014, 15:48
dodar's Avatar
Just my $0.02
The "or" you are referencing is between Overt Isolation and Holding; its not 2 different definitions. They are both still being modified by purposefully doing so. Over Isolation means that you are being obvious in keeping the ball away from the other alliance.
Unread 17-01-2014, 15:51
AKA: Ryan Guinn
Intent plays no role in possession.
Read G12
