Go to Post I didn't feel like reading this whole thread, which, as I understand, is talking about people not wanting to read long threads. - Mike [more]
Unread 17-01-2014, 03:58
brianbond's Avatar
brianbond brianbond is offline
Head Coach
AKA: Brian
FRC #5102 (The Underbots)
brianbond has a spectacular aura aboutbrianbond has a spectacular aura about
VexPro Pancake Shifter Question
Can't seem to find a definite answer on the size of threading for the fittings on the pancake shifter. Never ran one in the past so just trying to figure it out. If anyone knows I would love to know!
Thank you all!!
Brian Bond
Unread 17-01-2014, 05:53
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: VexPro Pancake Shifter Question
Thank you all!!
Brian Bond
The pneumatic fittings for the 3/4" 1/2" stroke pancake cylinder use #10-32 thread and are available here:
http://www.vexrobotics.com/217-2907.html
All dimensions for the cylinder are located on page 9 of this pdf:
http://content.vexrobotics.com/docs/..._Datasheet.pdf
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-01-2014, 08:57
ohdan56's Avatar
ohdan56 ohdan56 is offline
Commander-in-Chief
FRC #4284 (Highlander Robotics Fleet)
ohdan56 is an unknown quantity at this point
Would one of you be so kind as to explain to me the use/application of a pancake shifter? I am not familiar with this equipment. How does gearbox interact with the pneumatic cylinder? Thanks, I'm learning!
https://goo.gl/photos/8xZ9ixXRC3x14r5i7
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
DB
Unread 17-01-2014, 09:12
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
http://www.chiefdelphi.com/forums/attachment.php?attachmentid=15805&d=1389406671
http://www.chiefdelphi.com/forums/at...6&d=1389406997
Maybe Arthur can chime in for some more detail
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 17-01-2014, 09:56
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Glad to see this: Thanks, I'm learning!! (emphasis is mine). This is possibly the best trait anyone can have!
Unread 17-01-2014, 15:56
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
The use of pancake is referring to the geometry of the cylinder as well. As you can see from the attachments posted by geomapguy, the stroke needed to shift is very low, however you may still need a considerable amount of force to shift requiring a larger bore.
Proportionally the cylinder is short and wide, compared to more conventional pneumatics which may have a stroke 10x the bore.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 17-01-2014, 19:15
artdutra04's Avatar
The pancake pneumatic cylinder is a type of pneumatic cylinder that is as compact as possible.
Here is a drawing for a typical 3/4in diameter bore, 1/2in stroke (travel) pneumatic cylinder that is identical to what you can order from Bimba:
http://www.mcmaster.com/#6498k631/=qanv3j
As you can see, even through the stroke is only 1/2in, the overall length of the pneumatic cylinder is 5.03in long when fully retracted. The pancake cylinders in comparison were designed to be as short as possible for a given stroke; if you look at the same PDF I posted earlier a 3/4in bore, 1/2in stroke pancake cylinder is only 1.19in long. For shifting gearboxes there is no operational difference between a typical and pancake pneumatic cylinder, however the pancake cylinder is smaller and lighter.
For both the ball shifter and the dog shifter, the pneumatic cylinder is connected to a shifter shaft coaxially within another gearbox shaft. The smaller inner shaft can move in and out, while the gearbox shaft transmits the torque. For the ball shifter, there are balls in the gearbox shaft that can be pushed outwards via a step in the shifter shaft to engage into a gear and the gearbox shaft at the same time to transmit torque. For the dog shifter, a pin or screw attaches a dog to the coaxial shifter shaft to slide the dog to engage a gear into the gearbox shaft.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2014, 03:54
brianbond's Avatar
Head Coach
AKA: Brian
Thank you for that. It really helped!!!
