Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 17-01-2014, 23:37
Re: Relay Set toggling between Indexes?
Originally Posted by Invictus3593 View Post
Upon further investigation, we noticed that inside our compressor control loop (in periodic tasks) the WPI_RelaySet.vi is somehow toggling between relay 1, 2, and 3 by itself and also switching between forward, reverse and off relay modes.
I probed the inputs to this subvi inside the compressor control vi, everything is perfect. RelaySet should be getting Relay 1 as the index and forward as the relay mode, but probing inside RelaySet, even the controls are toggling uncontrollably.
This is expected. The same WPI_RelaySet gets called for all relays, so you're seeing the data from all calls, not just from where you went into it.
Are you actually having a problem, or just trying to find out why that error message is printing?
