Go to Post The neat thing about regionals, is that they ARE big robot parties! - MrForbes [more]
Unread 18-01-2014, 11:48
ZachTheSloth ZachTheSloth is offline
FRC #1719
ZachTheSloth is an unknown quantity at this point
How to communicate with the network table from the Dashboard
Curious how you communicate with the network table form the dashboard.
Unread 18-01-2014, 11:54
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: How to communicate with the network table from the Dashboard
The WPILib documentation has a bunch of information on how to use the SmartDashboard, you can find it here:
http://wpilib.screenstepslive.com/s/3120/m/7932.
In a nutshell, any call to one of the SmartDashboard methods will put information in or retrieve information from NetworkTables. The SmartDashboard.put/get methods wrap this for you, so you don't have to manually search for a NetworkTables key and find the value on your own. If you have any more questions, feel free to ask.
Unread 18-01-2014, 12:17
FRC #1719
Thanks, but I'm trying to communicate from the smartdashboard extension, so SmartDashbord.get won't work.
Unread 18-01-2014, 18:20
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
include the NetworkTables desktop .jar and use that.
Unread 19-01-2014, 15:00
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
You seem to be withholding information so I'll have to guess what you mean. You mention extensions, so if you are writing a plugin, you call observable.setData(someDataSpecifierObject) where observable is gotten from the DataCore via getObservable("some/path") inside the registered() method.
However, I somehow doubt that is what you meant and instead are wondering about the UI. In that case, simply use a UI element that supports sending like the sliders or number box, then when running drag/edit them and the value is sent back.
If I guessed incorrectly and you mean something else please clarify what you are trying to do
Watchdog.Kill();
