Go to Post FIRSTies always get Two Xmases! - [more]
Unread 18-01-2014, 13:08
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Post Team up date
Game Manual - Team UPDATE - 2014-01-17
root
Game Manual
Section 2.2.4: VISION TARGETS
The retro-reflective material on the dynamic VISION TARGET is nominally 3¾ in. from the FIELD-side surface of the ALLIANCE WALL polycarbonate sheet above the LOW GOAL.
Section 3.2.3: General Rules
G12
An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION:
“carrying” (moving while supporting BALLS in or on the ROBOT),
“herding” (repeated pushing or bumping),
“launching” (impelling BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT),
“trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Violation: TECHNICAL FOUL per instance. If extended, another TECHNICAL FOUL. If strategic, RED CARD for the ALLIANCE.
Examples of BALL interaction that are not POSSESSION are
A. “bulldozing” (inadvertently coming in contact with BALLS that happen to be in the path of the ROBOT as it moves about the FIELD) and
B. “deflecting” (a single hit to or being hit by a BALL that bounces or rolls off the ROBOT).
A BALL that becomes unintentionally lodged on a ROBOT will be considered POSSESSED by the ROBOT. It is important to design your ROBOT so that it is impossible to inadvertently or intentionally POSSESS an opponent’s BALL.
Section 4.6: BUMPER Rules
R26
In Team Update 2014-01-14:
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-10). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap between the backing material and the frame
the gap between the backing material and the frame must not be greater than ¼ in. deep, and or
the BUMPER must be backed by the FRAME PERIMETER at least every 8 in wide.
In Manual:
must not be greater than ¼ in. deep, and (change to “or” per last TU)
not more than 8 in. wide.
Section 5.1: Overview
In the event where order placement of ROBOTS matters to either or both ALLIANCES, the ALLIANCE must notify the Head Referee during setup for that MATCH. Upon notification, the Head Referee will require ALLIANCES to place their ROBOTS per the following protocol:
Qualification MATCHES
Blue GOALIE (if in use)
Red GOALIE (if in use)
Blue ROBOTS in the White ZONE
Red ROBOTS in the White ZONE
Elimination MATCHES
Lower seed GOALIE (if in use)
Higher seed GOALIE (if in use)
Lower seed ROBOTS in the White ZONE
Higher seed ROBOTS in the White ZONE
Section 6: Glossary
POSSESS: (for a ROBOT) to carry (move while supporting BALLS in or on the ROBOT), herd (repeated pushing or bumping), launch (impel BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT), or trap (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them) a BALL.
Unread 18-01-2014, 13:10
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Re: Team up date
It looks like you want this thread.
Welcome to CD. In the future you'll want to search for threads before starting them.
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Re: Team up date
Searching is really your friend
http://www.chiefdelphi.com/forums/sh...d.php?t=124798
Can someone remove the duplicate thread?r
