| Thread Tools |
Rating:
Display Modes |
Vision target location
For the vertical vision target. How far is it from the left edge of the poly goal assembly to the left edge of the vision target? (or right, doesn't matter)
I don't see numbers on the field prints |
Re: Vision target location
It's actually measured from the low goal. I don't remember the number but it is in the VISION TARGETS part of the rules.
Went thru the rules, watched the video, many times. No indication of what that exact measurement is.
I don't have time to check the drawings now, but there must be a measurement for the width of that piece of polycarb right? The center of the vision target is behind the edge of that polycarb so if you want the measurement to the edge subtract two inches.
Check out the CAD of the field. You should be able to get any measurement you want
#7
In all cases we have not found clear cut definitions of the measurements to the locations of the vision target. and how the horizontal and vertical target relate too each other. If you have clear cut definitions please post them for all. It would be nice if the center locations of each vision target was defined to say, the center of the goal wall There is a question on this on the FIRST Q/A Last edited by NotInControl : 19-01-2014 at 22:42. |
#8
Just some warning, I would be wary of using the FRC CAD models as definitive measurements. I know last year the Field CAD model was messed up with the complex pyramid and all. I'd anticipate that it would be better this year, but ya never know.
#10
I will have one of our CAD guys take a look, but I'm pretty sure he already did.
#11
EDIT: Fixed broken link. Last edited by billbo911 : 20-01-2014 at 11:08. |
#12
link to video is broken
#13
I think you can get the dimensions from this:
There are four (4) VISION TARGETS on each end of the FIELD: two (2) dynamic VISION TARGETS and two (2) static VISION TARGETS. There is one (1) dynamic VISION TARGET located above each LOW GOAL. Each dynamic VISION TARGET is located behind the polycarbonate panel on the ALLIANCE WALL. The dynamic VISION TARGET is horizontal and begins 5 ft. 8 in. above the FIELD carpet, is centered over the LOW GOAL, and consists of a panel with one (1) 4 in. wide, 1 ft. 11 ½ in. long strip of retro-reflective material (3M 8830 Silver Marking Film) adhered horizontally along the length of the panel with a 2 in. black ABS plastic border surrounding the retro-reflective material. The dynamic VISION TARGET is actuated to show the retro-reflective material when its corresponding HIGH and LOW GOAL are HOT. It will rotate to hide the retro-reflective material (pointing it upwards) when its corresponding HIGH and LOW GOAL are not HOT. Both of these conditions are shown in Figure 2-9. The static VISION TARGET is mounted such that half is behind the polycarbonate sheet above the LOW GOAL and half is behind the acrylic panel of the PLAYER STATION. It uses vertical reflectors which are located above the inside edge of the LOW GOAL. The vertical reflector consists of a 4 in. wide, 2 ft. 8 in. tall stripe of retro-reflective material bordered by 2 in. wide black gaffers tape on the left and right sides. The vertical reflectors begin 3 ft. 1 ½ in. above the FIELD carpet. |
#14
I posted two questions to the q&a last week: q157 and q158.
Sorry for the excessive use of abbreviations, was struggling to stay within character limits. I agree that there isn't enough information in the manual, any of the drawings, or the video to relate the targets to one another. Particularly in the horizontal dimension. The video defines the vertical targets position relative to the "inside edge" of the low goal. Does that mean the face of the cube furthest from the field perimeter, or does it mean the edge of the opening in the cube through which you could score a ball. I interpreted the later, but others on my team disagree. Also, are the measurements provided relative to the vision target's reflective material, or the black border which surrounds it? The game manual makes it sound like the black border is considered part of the target, so my hunch is the later, but this isn't an element of the field I want to approximate. I want it to be as accurately replicated as possible. This should be a relatively easy set of information for FIRST to provide, the game manual has all but one dimension defined already. Last edited by otherguy : 20-01-2014 at 10:21. |
#15
From that information, what is the horizontal distance between the two targets? And is that inclusive of the black border surrounding the reflective material?
