Go to Post Teach 'em young, and they will go far. - Vashts6583 [more]
Unread 18-01-2014, 14:15
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
Originally Posted by gyroscopeRaptor View Post
For your second question, divide your pneumatic section in two. Generation/storage and working air. On generation and storage, you can have 120 psi, and between generation and working air have a regulator set to 60 psi.
But can we use 120 on pistons?
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 18-01-2014, 14:19
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: Unmetered solenoids
They are called "cylinders" and no...you can only have 60 psi in the working system of your pneumatics...that is, the part that performs your mechanical tasks.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 18-01-2014, 17:49
If it isn't listed in R77, it isn't legal. That said, solenoids are fairly wide open--take a look at R77C, R77D, and R75--but also R74, which simply says that if it isn't listed, it can't be used.
Now, as for the second question: You have two pressures. Pressure #1 includes the compressor, pressure sensor, vent valve, at least one gauge, and as many storage tanks as you care to have at 120 psi--and a regulator. Figure 4-15 from R78 may be helpful here.
Pressure #2, on the other side of that regulator, is at 60 psi, and includes a gauge and however many solenoids and cylinders you happen to be using, possibly including more storage tanks and possibly some regulators as well.
Oh, and there IS a rule on this. R83 is what you were missing--it's a list of what can be at 120 psi. There are no cylinders or solenoids in that list.
Unread 19-01-2014, 15:00
Can you describe what you mean by "un-metered"?
