Go to Post Sleep well Chief Delphi, because for the next 6 weeks, sleep is only for the weak. :D - ttldomination [more]
Unread 18-01-2014, 16:51
Re: Switch help
Originally Posted by nelson.ke@ View Post
asking a question on how should I program that and maybe some pics of what teleop would look like. I want the motor to keep rotating until it hits the switch and then stop, a trigger on the controller would activate the cycle again so the motor goes around until it hits the switch again.
How fast will this be rotating? Do you want it to reverse direction when the trigger activates the cycle, or continue on "through" the switch one complete rev?
What motor controller will you be using?
