Go to Post I just turned 51 and I'm still not sure what I want to be when I grow up! - Mike Betts [more]
Unread 18-01-2014, 18:14
Thundrio Thundrio is offline
Dedicated Racer
FRC #3673
Thundrio is on a distinguished road
nullpointerexception when calling AxisCamera getImage()
We are trying to follow the sample code for vision provided with java, in order to get our own started.
We are getting a nullpointerexception when this line of code is run
ColorImage image = camera.getImage();
any advice on how to fix this / what is causing the exception? I can provide more detail if neccessary
Interested in a new way of playing old games?
visit http://www.speedrunslive.com for a way to make single player games multiplayer!
visit http://www.zeldaspeedruns.com to open up a new world for zelda lovers!
pm me here or at zsr for more information!
Unread 18-01-2014, 18:19
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: nullpointerexception when calling AxisCamera getImage()
Up near robotInit, make sure that the line initializing the camera isn't commented out.
Unread 18-01-2014, 18:21
Dedicated Racer
FRC #3673
Its not, and I think that would generate a different exception anyway.
Unread 18-01-2014, 20:28
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
In Java, a NullPointerException happens when you try to do something (like call a method or access a public variable) with a variable that is currently null. On that line of code, the only variable being accessed is camera.
Unread 18-01-2014, 20:38
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Yeah, I ran into this exact exception with one of my student's earlier today. It was a good opportunity to explain why null pointers occur. As you stated the camera in camera.{something} is the only thing that could be null in this case.
This is the robot init directly from the sample code:
public void robotInit() {
        //camera = AxisCamera.getInstance();  // get an instance of the camera
        cc = new CriteriaCollection();      // create the criteria for the particle filter
        cc.addCriteria(MeasurementType.IMAQ_MT_AREA, AREA_MINIMUM, 65535, false);
This is what it should look like after you uncomment the camera line
After this the camera should not be null. If it is still null however I would add a log line, something like this:
         System.out.println("construct the camera");
Make sure that line executes.
Remember the vision sample is based off SimpleRobot. If you are using something like IterativeRobot, etc this function may not be automatically called by wpi lib.
Adding that log line will let you know whether or not that code is even being executed.
Unread 19-01-2014, 01:49
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
A follow-up to lineskier's recommendation: print the camera variable right after initializing it inside of robotInit().
        System.out.println( "Printing camera: " + camera );
If camera is indeed null, as it almost certainly is, you will see this:
Printing camera: null
I am not sure what would make this return null...other than having a misconfigured Axis camera. If you open a web browser and type in a url of 10.xx.yy.11 (where the xxyy is 3673, your 4 digit team number), do you connect to the Axis camera? If not, then you will need to reconfigure your camera. Here is the WPI page for configuring an Axis camera:
http://wpilib.screenstepslive.com/s/...an-axis-camera
Good luck and post again if this doesn't help. Once you get it fixed, let us know what fixed it so that the thread becomes a resource for others.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
