Go to Post If you're not trying to make the best possible product given your set of constraints and resources I'm not quite sure what you're doing. - Aren_Hill [more]
Unread 18-01-2014, 12:48
tjspartans tjspartans is offline
FRC #3648
tjspartans is an unknown quantity at this point
Can we use a manufactured winch?
Hi, my team is using a winch that we found at Home Depot to shoot the ball, and we wondering if it is allowed to use this part. It is a Reese Towpower #1500 Winch.
Here is the link of the winch: http://www.homedepot.com/p/Reese-Tow...329/202328202#
If anyone can let me know if this is legal, it would be greatly appreciated. We looked through the game manual, but couldn't find anything that helped to answer this question.
Unread 18-01-2014, 13:10
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Re: Can we use a manufactured winch?
That winch does not have a FIRST approved motor.
Unless you change out the motor to an approved one (listed in the game manual) then no, it won't be legal.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 18-01-2014, 13:28
FRC #3648
The winch that we got did not come with a motor, and we planned on using gears and a FIRST approved motor. What we were worried about was the winch itself and the fact that it is a manufactured part. We just wanted to make sure that using it wasn't going against regulations.
Unread 18-01-2014, 13:48
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
This is perfectly acceptable to use. However, if you are using it to release and pull back a spring-loaded device, you need to consider how you release the mechanism for it to fire.
If you are back driving the motor with springs, your results will be much less impressive than if the motor becomes disengaged from the winch entirely.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 18-01-2014, 18:24
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
From experience testing a similar hand winch from Harbor Freight, one thing to consider is how heavy the spool is on such a device. Accelerating such a heavy spool uses quite a bit of energy.
Unread 18-01-2014, 19:16
Physicguy's Avatar
Physicguy Physicguy is offline
It exploded on its own I swear...
AKA: Jeffin James
FRC #2582 (Pantherbots)
Physicguy is just really nicePhysicguy is just really nicePhysicguy is just really nicePhysicguy is just really nice
Last year we used a manufactured winch for our climbing mechanism... For us getting the winch to couple with gearbox was the difficult thing. So be careful on what type of winch you use.
Unread 18-01-2014, 22:29
There doesn't appear to be any rule that I see is violated. However, as others have stated, safe use of all parts is one of our prime directives. Please consider failure modes and other safety issues in your design.
