Go to Post I think that this clearly indicates that 2017 will be the year we finally see 3.63 robots per alliance. - Caleb Sykes [more]
Unread 18-01-2014, 10:02
pabigfe97 pabigfe97 is offline
pabigfe97 is an unknown quantity at this point
How to program Spike Relay in LabView
I've been having some trouble coding the spike relay for some time now, i can't get it to work at all... Could anyone tell me, with detail, how to code a spike relay in LabView?
Thanks!!
Unread 18-01-2014, 10:24
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: How to program Spike Relay in LabView
Can you explain what exactly are you using the relay for and when it stopped working? Also if you could post a screenshot of the code for the spike.
Unread 18-01-2014, 18:52
The way to be sure that the programming is correct is that the Relay LEDs on the Digital Sidecar will light up red and green.
Here is one example that will just light the green Relay LED beside Relay 1:
Another example can be found from the Getting Started window in the LabVIEW Support->FRC Examples
Unread 21-01-2014, 22:14
Dexterium's Avatar
Dexterium Dexterium is offline
AKA: Adam Poindexter
FRC #1208 (Metool Brigade)
Dexterium is an unknown quantity at this point
The above example code is great, but lacking something important.
There are 4 states you can set the relay to be.
  1. On
  2. Off
  3. Forward
  4. Reverse
On should never be used
Off is just off (Yellow light)
Forward is a positive 100% (Green light)
Reverse is a negative 100% (Red light)
