Go to Post Come on, guys, it's two weeks 'til build. Personally, I'm gonna go outside for a little before I forget what my neighborhood looks like in the daylight. :) - Libby K [more]
Unread 18-01-2014, 19:04
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Can't Permanently Deploy From WindRiver
When I select the Deploy option from the FIRST menu in WindRiver, the process never finishes. WindRiver doesn't freeze or hang, but the Deploying... window never goes away and can't be cancelled.
Oddly, when I FTP into the cRIO, I can see that it successfully creates the FRC_UserProgram.out file, but it remains empty (0 bytes.) Undeploy works just fine.
Unread 18-01-2014, 20:14
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Can't Permanently Deploy From WindRiver
Does the file you are asking to FTP actually exist?
Unread 19-01-2014, 08:22
AKA: Brad
#0190 ( Gompei and the Herd)
Have you set up the path to the file correctly in the Workbench settings as described here?
http://wpilib.screenstepslive.com/s/...ct-to-the-crio
Brad Miller
Robotics Resource Center
Unread 19-01-2014, 10:32
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Remember if you change projects, to change the First downloader preferences. Try turning off windows firewall. Ensure that the target is connected by the fact that you can see the running processes. You could try manually ftp'ing the file to make sure it can write to the crio.
Brian K
Team 1225 Robotics Mentor
Unread 19-01-2014, 10:37
bvisness's Avatar
The path is correct, the FIRST Downloader settings are correct, and I can manually copy the .out file to the cRIO. I guess I haven't checked the firewall in detail, but as I said before, Undeploy works fine, so this doesn't seem like a firewall issue at all.
