Go to Post Don't put sprockets in an empty pizza box and then throw it into the garbage. Something we learned from experience. - Herodotus [more]
Unread 16-01-2014, 12:02
Jmulderig Jmulderig is offline
FRC #3460
Jmulderig is an unknown quantity at this point
help repairing 2014 game pieces
Has anyone repaired or know the best way to fix a popped ball....we had an oops. Yes we have looked at and seen all the google methods for exercise balls. We just want to know if anyone as actually performed the procedure.
Unread 16-01-2014, 12:06
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: help repairing 2014 game pieces
So we might all learn, how did you pop the ball?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 16-01-2014, 12:12
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
I have seen talk of duct tape working, although we haven't needed to yet. Gaff tape might work even better too.
For a more robust fix you might try a bicycle tire patch. I don't know if it would work any differently because of it being a different material, but I imagine that it would work. I'm interested to hear if you try any solutions that have not been discussed yet.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 16-01-2014, 12:20
FRC #3460
Pretty easy....1"Aluminum angle catapult arms...ball bounced back off wall and hit the exposed non-filed corner at the end of the arm. Was a prototype so did not make the ends all nicey nice
Unread 16-01-2014, 12:21
FRC #3460
I just emailed SPORTOGO if they dont give me the "we dont recomend reapiring" speech i will post their answer.
Unread 16-01-2014, 12:24
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Our head coach emailed Sportogo, and their response was something along the lines of "There is no adhesive that can repair a ball that is less than 36 inches in diameter."
Unread 16-01-2014, 12:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Sounds like a job for Gorilla tape
Unread 16-01-2014, 12:49
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
rubber cement, and then duct tape over that. I've repaired a lot of waterbed and airbed bladders like that and it "usually" works. Give it a couple of hours to set, or more.
Unread 16-01-2014, 12:52
lgphoneeric's Avatar
lgphoneeric lgphoneeric is offline
FRC #2996 (Cougars Gone Wired)
lgphoneeric will become famous soon enough
I don't know if you have a Costco in your area, but they have the exercise ball there for sale. So as long as your fabric is still good, you could just get a new ball.
If you have everything under control, something's about to break.
Former FRC Driver, Alumni, Mentor
Unread 18-01-2014, 13:45
Nonsense.
Try Shoe Goo if you can find it. It sticks to everything* and remains flexible.
Try this:
Cut a patch of denim,
Rub Shoe Goo into the patch and on the tear,
Press the patch onto the tear,
Put several layers of newspaper over the patch**,
Put a heavy object on it to hold the pressure, and
Give it 24 full hours to cure.
* I repaired the torn seat of my (heavily used)yard tractor with it. It was split open and the foam as bulging out. That was 2 years ago.
** to allow the VOCs to escape
Unread 18-01-2014, 14:57
I emailed Sportogo about repairing one of their 40 inch balls, and their response was "There is no adhesive that can repair a ball that is less than 72 inches in diameter."
(just kidding)
Unread 18-01-2014, 19:19
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
Well I own swimming pool service company and I would use a pool liner repair kit. I have been successful using them to patch tire tubes. Just be careful because the glue might melt the rubber ball. If you get the patch to stick put duck tape over it put it in the cover and fill with air. Try it what do you have to lose you all ready killed it.
Unread 19-01-2014, 21:48
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Our ball has a pin prick size hole that is causing a slow leak in it. Someone bought a patch kit and attempted to repair it yesterday, but we haven't tried to re-fill it with air since. We meet again Tuesday and if the repair was successful I can post info on what repair kit was used.
Unread 19-01-2014, 22:10
MrForbes's Avatar
AKA: Jim
The web page says the bladder is made of PVC. Isn't that what the pool liners are made of?
Unread 19-01-2014, 22:17
gracie.'s Avatar
gracie. gracie. is offline
forgot the heat shrink...
FRC #2399 (The Fighting Unicorns)
gracie. is an unknown quantity at this point
We found a tiny hole in our ball caused by a splinter that was causing it to deflate rapidly. Patched with regular old duct tape and holding air fine again.
2399: The Fighting Unicorns! - Alumna, team sister | Dean's List Finalist 2013
Anyone need a mentor in west LA?
