Go to Post It's OK to make some mistakes, as long as you learn from them. - Doug G [more]
Unread 18-01-2014, 19:50
ShadowWing's Avatar
ShadowWing ShadowWing is offline
FRC #3501
ShadowWing is an unknown quantity at this point
Mecanum Drive with Encoders?
Hi, our team is using mecanum wheels on our robot, however, we're not using RobotDrive for the 4 mecanum wheels. Instead, each wheel is hooked up to its own jaguar and we are using each jaguar independently.
With that in mind, could someone help me understand how to code encoders using this set up?
Unread 18-01-2014, 20:16
Re: Mecanum Drive with Encoders?
Are you using CAN or PWM to control the Jags?
If you're using CAN, you can plug the encoders directly into the Jags. Jags have built-in firmware to decode the encoder signal and do closed-loop speed, position, voltage, or currrent control.
Unread 18-01-2014, 20:19
ShadowWing's Avatar
FRC #3501
We're using PWM
Unread 18-01-2014, 20:42
We're using PWM
Then you'll have to connect each encoder to the DSC. WPILib file "Encoder.java" has classes for handling encoders.
