Re: IP Error for cRIO II Imaging
My team has spent several hours over the last week trying to image the cRIO. We found that the most reliable way is to reset the cRIO with the method above, and then image it from driver station. For some reason only the driver station would work without fail.
There are several threads on imaging tips.
1. Disable all other network adapters except the wired adapter doing the imaging (wireless, etc) 2. turn off windows firewall 3. Use a swap cable directly from the pc to the crio or go through the router on the robot with only the two things plugged in 4. Always image with a cable, not over wireless 5. Double check the ip address typed in is correct. 6. Ensure correct image is shown. |
