Go to Post Liberal arts majors learning more STEM concepts along with STEM majors learning more 'liberal arts' is a good idea. - ebarker [more]
Unread 18-01-2014, 20:32
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
arduino control of motor controllers
I'm not sure if this has been covered, but the Arduino sample Knob http://arduino.cc/en/Tutorial/Knob works great for quick testing of mechanisms. Just place any standard FIRST motor controller in place of the servo, and you have a easy variable speed control without CRIO programming.
We hooked an Adafruit Flora to a Talon and a Cim and our prototype ball disintegrator worked great.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 19-01-2014, 08:18
AKA: Brad
#0190 ( Gompei and the Herd)
Re: arduino control of motor controllers
While that is a good way for quick tests, just be aware that it is not legal in competition. And as a long term solution, not recommended. There are many safety mechanisms built into the FRC control system that, for example, turn off the motors when the robot is out of range of communications or when the robot is disabled. Using the Arduino to control the motors bypasses all of them.
Brad Miller
Robotics Resource Center
Unread 19-01-2014, 10:23
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
We played with this in the off season. A couple of things:
Use the version of server.attach() version that specifies pulse widths that the controller you are using likes. This is for a talon:
// motor drive server connected to a TALON
driveServo.attach(3, 1000, 2000); // TALON // widths are in micro-seconds
You will need to calibrate the speed controller. I wrote a sketch that prompts the user though the calibration starting with pressing the button and uses input from the serial port to advance thought forward, reverse, and back to idle.
Brian K
Team 1225 Robotics Mentor
