Go to Post Adding an ounce or two of shields is way easier than filling out the mountains of paperwork for that one impatient person to stick their arm into the robot reaching for who knows what only to have their fingers meet up close and personal with a gearbox. - artdutra04 [more]
Unread 13-01-2014, 16:08
AdamWiwc AdamWiwc is offline
FRC #5185
AdamWiwc is an unknown quantity at this point
Can Victor and Jaguar motors work together on a single gearbox?
We have three Victor motor controllers and two Jaguar motor controlers, can we put those together on a single gearbox so that we have two motors on each side of the robot totaling of four motors? Is it a better idea to use one of each type on either side or two Jaguars on one side and two Victors on the other?
Thanks for your time.
Team 5185
The dial up grizzlys
Unread 13-01-2014, 16:10
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Can Victor and Jaguar motors work together on a single gearbox?
It's not really recommended to do anything but all the same controllers for the drive motors.
If I was in your case, I would put a Victor and a Jaguar on each side. While this could lead to unequal loading of the two CIMs at any part load point, IMHO it's better than the robot drifting to one side because of controller difference.
Kettering Motorsports
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The Victors, Jaguars, and Talons all have different response curves - meaning if you told them all to go the same speed in the code, the actual results would be a little different. Thus, it's not recommended that you use different speed controllers with the same gear box. Also, for good control of your robot I would make sure all the speed controllers on the drive train are the same!
2016: Lake Superior WFFA
Unread 13-01-2014, 16:15
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Generally no, the pwm rates for Victors and Jaguars are different, so they would not work off a splitter. Additionally they provide different powers at the same joystick position unless you do a bunch of fancy programming to equalize the 2.(I have not heard of anyone attempting this)
It is recommended to always use the same controllers for multi-motor gearboxes.
Unread 13-01-2014, 17:11
Yes they would. Both Vics and Jags will operate properly with PWM period ranging from 5m to 20ms.
True for the Vic884, not so much for the Vic888. Even so, all it means is that one motor is carrying more load than the other.
Unread 16-01-2014, 23:35
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
You have a lot of teams in Calgary and you can possibly trade with one of them. It could be quicker and if you are on a budget you can save the purchase price. Teams in our area have loaned and traded parts for years when needed.
KF6UZX
Unread 17-01-2014, 07:01
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team 5185
We mixed jaguars and victors on our 6 motor drivetrain last year. 2 Victor 888s and 1 jaguar per side.
While it works, we noticed the jaguar motors working much harder than the Victor ones, and had to write some code to rebalance everything. The jaguar motors were heating up while the Victor motors weren't.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 18-01-2014, 20:44
DonRotolo's Avatar
Back to humble
FRC #0832
Precisely.
The answer to the OP is "yes". But: Some motors will work harder than others, because the curves for the controllers are different.
Unread 18-01-2014, 21:11
Originally Posted by Mr. Lim View Post
we noticed the jaguar motors working much harder than the Victor ones ... The jaguar motors were heating up while the Victor motors weren't.
OK CD community: What's the underlying physical explanation for why this happens?
@Mr Lim: Just to eliminate one possibility: Are you certain the brake/coast settings were identical on all controllers?
Unread 18-01-2014, 21:17
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
When a Jag and a Vic are shown the same PWM signal, which develops more voltage at its motor terminals?
Richard Wallace
since 2003
Unread 18-01-2014, 21:20
RMS or arithmetic average ?
Unread 18-01-2014, 21:32
Let's go with arithmetic average for now.
Richard Wallace
since 2003
Unread 18-01-2014, 21:33
AKA: Mr. Lim
I'd like to hear an explanation for this one. Although I'd have to check the PWM / Voltage curves more carefully, my guess is because the Jags have a more linear response, in general for any given PWM signal they would produce a higher (magnitude) voltage than a Victor, except for at the extremes, where they would be the same (Vbatt).
Yes, I am certain both would have been on coast.
Our drivetrain runs open loop most of the time, and we do check that all speed controllers on it are specifically set to coast.
Unread 18-01-2014, 21:34
AKA: Mr. Lim
RMS, assuming we drive both forwards and backwards... or turn!
Unread 18-01-2014, 22:05
Are you also certain that:
all the controllers were properly calibrated
and
your code was using the appropriate input pulse width range for the Jags and the 888s?
