Go to Post resistance to FIRST is futile. - King Duke [more]
Unread 18-01-2014, 21:42
Re: Forklift
Do you want the joystick to control the speed of motion of the motors? You can just get the joystick x-axis value and wire it to a motor set function. That way, if the joystick is centered the motor does not turn, and the farther away from center the joystick is moved, the faster the motor turns.
