Go to Post I bet Andy Baker would totally own JVN in a 1v1 dodgeball fight. - Greg Marra [more]
Unread 18-01-2014, 13:00
DarthMaulCIS DarthMaulCIS is offline
FRC #4607
DarthMaulCIS is an unknown quantity at this point
Forklift
So we have a forklift on our robot that my team wants to be controlled by the joystick instead of a button. I don't know how i would go about that, as far as teleop.vi programming.
Unread 18-01-2014, 13:06
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: Forklift
Tell us a little bit more about the forklift mechanism. How is it driven? What does it do?
Per Audacia Ad Astra
Unread 18-01-2014, 14:09
FRC #4607
Re: Forklift
"Two miniCIM motors are connected to two sprockets via #25 chain. The motors are run in tandem to move the forks." As dictated by my teammate.
Unread 18-01-2014, 14:10
FRC #4607
Re: Forklift
They want it to be tied to the x-axis of our joystick. I am thinking it would be easier for everyone to have two buttons lower/lift the forklift instead.
Unread 18-01-2014, 14:22
Re: Forklift
You can read the joystick axis like a potentiometer (-1 to 1), then map the position of the forklift with a PID loop and some encoders using the joystick axis as the setpoint.
If you don't know how to use PID or what it is, a quick search on this site will bring up many helpful links.
Unread 18-01-2014, 21:42
Re: Forklift
Do you want the joystick to control the speed of motion of the motors? You can just get the joystick x-axis value and wire it to a motor set function. That way, if the joystick is centered the motor does not turn, and the farther away from center the joystick is moved, the faster the motor turns.
