Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Unread 18-01-2014, 22:07
Re: Can Victor and Jaguar motors work together on a single gearbox?
Originally Posted by Mr. Lim View Post
I'd like to hear an explanation for this one.
Do you still have last year's bot?
Could you bring it back to life and run a few quick tests?
1) wheels up (bot on blocks): test voltage* at Jag's and 888's motor outputs at several throttle settings
2) bot pushing against a wall: carefully repeat above test with low throttle settings (to avoid overheating)
* measure both true RMS and arithmetic average. true RMS requires a voltmeter that specifically has that capability.
