Go to Post Is it January yet?? - Kevin Kolodziej [more]
Unread 19-01-2014, 00:03
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
pic: Found It!
Unread 19-01-2014, 00:04
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: pic: Found It!
What's the code/setup behind this?
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 19-01-2014, 00:07
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: pic: Found It!
Would you describe the algorithm you are using to detect the ball?
http://team2168.org
Unread 19-01-2014, 00:23
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
jmartin is on a distinguished road
Re: pic: Found It!
I too would be interested in what algorithm is being used. More specifically, since you seem to be using a Kinnect, are you using the point cloud data to help identify the ball?
I know I'm really excited to use ball tracking to try to do some automated catching. I had though about using a Kinnect, but I don't think the raspberry pi we're using for onboard vision processing would be able to process fast enough using the Kinnect. What cool things are you going to do with your ball tracking?
Unread 19-01-2014, 10:08
mwtidd's Avatar
AKA: mike
Re: pic: Found It!
Where you could probably get the kinect working with some linux distribution, I'm not sure if some the of the features of the kinect sdk are readily available from the open kinect projects and such. Specifically the ability to map color pixels to depth pixels.
I simply used the straight microsoft c# sdk, and used the KinectExplorer example as a basis.
My theoretical setup would include a nuc, an arduino and a kinect. My thinking was that I would use the arduino to relay the target's x, y, and depth back to the crio. Avoiding any of the issues that may occur passing this data through the network.
The algorithm should be able to be reproduced, and is not perfect. The first thing I put it through is a blob area and color threshold.
The color threshold is a max red, max green, min blue, and max average color.
For area, essentially I find a pixel that meets the color threshold, and then recursively fan out from there, finding any neighboring pixels, and checking them too. Each returns 1 or 0 to indicate whether the pixel is hot or not. As its recursive I can get the area of the connected blob.
I then calculate the distance to the center of mass of that blob.
The center of mass is often not the actual center of the ball, so I then you the depth sensor to find neighboring pixels, to find the closes pixel to the camera. My minDepth function also only accepts values that are > 90% of the current minDepth. Which helps to avoid any foreground items.
I then maintain a 5 frame running average of x and y, and use that for the position. Downside to this right now is that if I get a false positive it could take several frames for the target to reacquire.
It's far from perfect, but I do like the idea of being able to find the center of the ball based on depth as opposed to color. I am considering trying to get a kinect v2 developer kit, to see if I can get something put together for next season. Kind of like the startings of a wpilib type thing for the kinect.
The biggest issue is weight and power. I would personally prefer powering the nuc and arduino off a 19v battery than the power supply. Something like this: http://www.xpalpower.com/energizer/xp18000a.php. I guess I could resell it and make it a cots item:
http://www.newegg.com/Product/Produc...82E16856102001
But i'm not sure that nuc sale price will stick around for long. I also would prefer having the nuc with the i5 for obvious reasons. I guess if I come up with it, I'll just have to find a more FIRST friendly way of providing voltage boosters.
It's also probably around 5 pounds for the set up... Certainly more than most teams would be willing to spend.
