Go to Post Wow, what a regional at St. Louis! ... It's gonna be a good year for FIRST. - Andy Baker [more]
Unread 19-01-2014, 03:46
Gwen_McD's Avatar
Gwen_McD Gwen_McD is offline
AKA: Gwen McDowell
FRC #1504 (The Desperate Penguins)
Gwen_McD is an unknown quantity at this point
Bumpers re: Frame Skewing
One of the persistent issues our robots have encountered is frame skewing due to corner impacts. Would appreciate any experienced advice regarding the bumper configuration/construction/mounting you have found to minimize or prevent skewing. Thanks!
Unread 19-01-2014, 09:37
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Bumpers re: Frame Skewing
Your bumpers can weigh 20lbs, so screw some angle onto you wooden backing. We use 3/4" aluminum angle that is 1/16" thick and it reinforces ours pretty well. We put one in each corner, and also tie the sides together and use them for mounting to the frame.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 19-01-2014, 09:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you provide a picture of your robot, we might be more helpful.
But the normal way to avoid this problem is to attach a sheet of something flat, such as plywood or aluminum or polycarbonate sheet, to the bottom of the robot.
Unread 19-01-2014, 09:50
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Bumpers won't necessarily solve structural issues with a rectangular frame. Do you include any cross bracing to make your frame into triangles?
If you install a floor (such as for the electronics) and use enough bolts (more than 4),it can act as structureto prev ent skew.
Unread 19-01-2014, 10:04
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
If possible, follow Mr. Forbes advice with a thin belly pan to help skewing. If you have ever built a cheap book case, then you will understand the value of a backing or belly pan. That thin piece of cardboard applied to a stick frame will help skewing a ton. Now if twist is a concern... that may require a different solution.
Unread 19-01-2014, 10:38
I made my earlier comment assuming that you already had your frame solid. I strongly recommend following the advice of everyone else in this thread first. Cross bracing and a belly pan on your frame is going to make the biggest difference.
If you are still concerned with impact, reinforce your bumpers. They are designed to transmit forces more evenly to the frame. The frame is still going to take a hit, but it should be distributed better by the bumpers.
Andrew Basse
Unread 19-01-2014, 16:36
Gwen_McD's Avatar
AKA: Gwen McDowell
Smile Re: Bumpers re: Frame Skewing
Thanks very much for all of your suggestions. I suspected this issue couldn't be solved with bumpers, but wanted tried and true advice to be sure. I appreciate your expertise and the time you took to help us.
