Go to Post OK, repeat after me "FIRST is not about the robot". - Foster [more]
Thread Tools Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 18-01-2014, 18:26
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Thoughts on the new AM14U 2014 KOP Drive train?
Originally Posted by SargeUSMC View Post
Does anyone have a drawing of the side rails with dimensions at all? Specifically the dimensions for the center area where the drive hardware bolts up. I'm trying to determine what modifications may be needed for the 2 CIM ball shifters we bought.
You can always measure the official CAD models.
  #62   Spotlight this post!
Unread 18-01-2014, 18:49
SargeUSMC's Avatar
SargeUSMC SargeUSMC is offline
AKA: Bob Rosso
FRC #3015 (Ranger Robotics)
SargeUSMC will become famous soon enoughSargeUSMC will become famous soon enough
Thanks Max. I saw that on their site. I was hoping to land a pdf so I could play with this at home here, but I'll take all the help I can get. I do appreciate it. I can't manipulate it myself here, but I'm sure I can get it done at school.
If anyone has a pdf drawing with those center dimensions to share, that'd be great.
Thanks again.
SEMPER FI
  #63   Spotlight this post!
Unread 18-01-2014, 19:33
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
The pages for the individual plates have layout drawings.
Inner Plate: http://files.andymark.com/am-2567%20...-%20Folded.PDF
Outer Plate: http://files.andymark.com/AM-2572%20Outer%20Plate.PDF
  #64   Spotlight this post!
Unread 18-01-2014, 19:35
SargeUSMC's Avatar
AKA: Bob Rosso
AHA! Those I didn't see!
I looked at the diagram for the inner plate and unfortunately there aren't any dimensions in the center there except for the larger holes. I'll have to see what I can get from the .step.
Thanks loads for your help, Gary.
  #65   Spotlight this post!
Unread 18-01-2014, 21:58
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We did this today. Used a bearing to locate with the transmission sideplate and a transfer punch to mark the 4 mounting holes. You may need to slot the upper hole as shown for the shaft.
Check the gearing for your application.
  #66   Spotlight this post!
Unread 19-01-2014, 08:50
SargeUSMC's Avatar
AKA: Bob Rosso
Thank you kindly sir. Puts me in the ballpark. 'preciate it.
Semper Fi.
  #67   Spotlight this post!
Unread 20-01-2014, 00:09
styxracer97's Avatar
styxracer97 styxracer97 is offline
2015 Drive Team
AKA: Liam Kosloski
FRC #0093 (NEW Apple Corps Robotics)
Team Role: Driver
styxracer97 is an unknown quantity at this point
My team is actually designing a custom chassis based off of the KOP one, it is very nice option in my opinion.
  #68   Spotlight this post!
Unread 06-02-2014, 14:15
Oblarg Oblarg is offline
AKA: Eli Barnett
So, after working with this thing for a while, here's some more developed feedback:
1) Direct-drive center wheel is fantastic, and I like how easy it is to mount nonstandard gearboxes.
2) The sheet-metal construction is nice, but would benefit from more rigidity - even with the stiffeners it's more wobbly than I'd like.
3) There is absolutely no good reason for the outer plate to be set lower than the inner - all this does is make mounting things harder. Mounting to the frame is, in general, easier than in previous years but still a pain.
4) Having to remove the outer plates to do any reasonable drive maintenance is horrible. Serviceability is one of the core design features of any good FRC drive, and servicing the AM14U looks to be a real pain. Time will tell if it becomes a problem at regionals.
5) There should have been holes pre-drilled for construction in alternate frame dimensions - it's a lot more effort this year than in previous years. The lengthwise plates are the cause of most of the issues; having to make that weird angle cut, and additionally hacksaw off a portion of the flange is really annoying, and it's compounded if you're not going 23x32 and thus need to drill a whole bunch of new holes as well (which could easily have been pre-drilled without compromising structural integrity)
6) Belt tension is very good compared to last year, but still seems a little loose on all three of the AM14U's I've seen.
Final note: Churro stock is probably my favorite new AndyMark product over the past two years. I absolutely adore it.
"The breakfast of champions!"
  #69   Spotlight this post!
Unread 06-02-2014, 14:28
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
Seconded- we are using a modified kitbot chassis and we might have 34 total pieces of churro for support in the drivetrain... We shouldn't bend or break at all I hope
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
  #70   Spotlight this post!
Unread 06-02-2014, 15:35
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Have you considered just putting pieces of lumber like 2x4s between the rails? Some very well known teams (1114 in 2008 I believe) have done this in the past and it makes for a very rigid system.
  #71   Spotlight this post!
Unread 06-02-2014, 15:43
Alan Anderson Alan Anderson is online now
A couple of our students have gotten really good at removing and replacing those. If you have a good electric nutdriver, it's not really a big problem. The only issue I see on our team's robot is all the stuff that somehow has ended up mounted to the side plates' flanges.
  #72   Spotlight this post!
Unread 06-02-2014, 16:55
AKA: Eli Barnett
We attempted a "do not mount anything to the outer plates" rule, but quickly abandoned it when it became clear that there was absolutely no other feasible way to get our roller arm on our robot (it was still hard, though, because the outer flange is inexplicably not at the same height as the inner one). It's thankfully not all that difficult to remove with our current design, but it's still a pain.
Even with an electric nutdriver, it's not something I want to be doing between matches. You should not need to remove a critical structural element of your chassis to get access to the belts or the center wheel. I hope they change this next year.
  #73   Spotlight this post!
Unread 06-02-2014, 16:57
Rynocorn's Avatar
AKA: Ryan Jacobs
Yeah we were going to try it but our electronics and pneumatics are all packed down in there and the respective captains didn't really support my motion to put large pieces of wood through the middle
