Go to Post Once you try hex you'll never go back. - IndySam [more]
Unread 19-01-2014, 11:37
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Exclamation BIG Problems with the New Talons SR!
Hello! Our team has a very big problem with the new Talons Sr. I know that if they are flashing orange, there is no signal or they are not working. The thing is that sometimes they work (they don't flash orange), sometimes they don't work (they flash orange), sometimes they all work for only 5 seconds, etc. We've tried everything from redoing the code (with two programming mentors double-checking and confirming that there's nothing wrong with the code) to rebooting the cRIO to restarting the robot to changing the PWM cables to changing the places on the Digital Sidecar to changing everything but the kitchen sink! Could someone please help us?
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 19-01-2014, 11:42
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: BIG Problems with the New Talons SR!
If you try a different type of speed controller does it behave properly?
Unread 19-01-2014, 11:43
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Have you tried using something other than the Talon? If the same issue occurs, then problem isn't the controller. Also, are you sure that the black wire of the PWM cable is lined up with the 'B' on the Talon?
Here is the Talon User Manual.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 19-01-2014, 11:44
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
I'd also check to see if your Digital Sidecar is fully powered. Are all 3 lights glowing bright on the Sidecar? Does the Signal Light flash at all?
I'm right 90% of the time, so why worry about the other 3%?
Unread 19-01-2014, 11:45
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Unhappy Re: BIG Problems with the New Talons SR!
Dear Alexander,
I'm sorry you're having such much trouble right now. Let CD try to help you get over this hurdle.
Can you try a sideways solution? Can you get hold of another method to drive the PWM signals like a VEX controller or one of the signal generators that output just a PWM signal? IF you can confirm that you have a known good PWM signal that may help your debug efforts to be directed to the cable , power connections and the Talon SR itself.
Regards,
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 19-01-2014, 11:46
mickztlin mickztlin is offline
Y_SO_CRIO
FRC #2637
Team Role: Electrical
mickztlin can only hope to improve
If everything were to be workig perfectly (components and such), do you know if the side car is conected to the pd board? I know its probably something wrong with the talon, but im just checking.
To the victors go the swarf!
Unread 19-01-2014, 11:55
Hoover's Avatar
Hoover Hoover is offline
no team (None)
Hoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to all
Check for metal filings in the Digital Side Car. It is the perfect place for them to fall and short contacts. Look close as they are tiny. This happened to us last year. We tried our best to cover electronics when working but now we try harder.
Unread 19-01-2014, 14:40
Brandon Ha Brandon Ha is offline
FRC #0302 (Dragons)
Brandon Ha is on a distinguished road
Could you possibly have a low battery issue?
I know that when they do not show any light that could be a issue
We all make mistakes.
I make one everyday.
The important thing is.
( \_/ )
(^_^)
Unread 19-01-2014, 14:58
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
sounds like the ribbon cable to me. the cable that runs from the crio to the digital sidecar. check that it is fully seated. try a different one. the probability that multiple talons went out at once seems unlikely to me so check anything that can affect them all at once
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 19-01-2014, 18:43
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
Did you remover the factory installed jumpers? They are small enough to over look.
Unread 19-01-2014, 18:49
cmwilson13's Avatar
what jumpers are you referring to?
Unread 19-01-2014, 18:58
Chris_Ely's Avatar
AKA: luckof13
If you are referring to the coast/brake jumpers, they have to be installed in order for the Talon to work properly. Setting the jumper to coast will allow the motor to rotate freely when the Talon is disabled. Setting it to brake will prevent the motor from rotating when disabled.
Unread 20-01-2014, 23:45
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Sounds like its an issue that presents across multiple speed controllers, so I would sanity check the Digital Side Car (try another?). Lots of good suggestions above. If you have an oscilloscope you can confirm if the PWM pulse looks good. Talons and Talon SRs decode PWM the same way so I don't think it's SR related.
Unread 21-01-2014, 06:06
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
+1 on this. We've had metal chips in the Digital Sidecar several times over the years, and they can cause all sorts of bizarre behavior. Talons are pretty hard to hurt.
