Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Unread 17-01-2014, 22:50
ninjosh97's Avatar
ninjosh97 ninjosh97 is offline
ninjosh97
AKA: Josh
FRC #2655 (The Flying Platypi)
ninjosh97 is an unknown quantity at this point
Teleop Periodic vs Teleop Continuous
What is the difference between Teleop Periodic and Teleop Continuous?
Which should I use for say... my drivetrain code?
Thank ya much!
Josh H.
Team 2655, 2013-14 Season President
4 FLL Seasons
3 FRC Seasons (So far)
Unread 17-01-2014, 23:12
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Teleop Periodic vs Teleop Continuous
TeleopPeriodic is called at a regular interval (about every 20ms), synchronized with the Driver Station packets. TeleopContinuous is called repeatedly as quickly as possible. Use of TeleopContinuous is deprecated; you should use TeleopPeriodic instead.
Correction: As stated below, TeleopContinuous is not deprecated, but removed. You should still use TeleopPeriodic.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 17-01-2014, 23:15
Deprecated usually implies that it still works. TeleopContinuous has been removed from the IterativeRobot base class and won't be called by anything even if you put code in it.
Unread 19-01-2014, 13:03
ninjosh97's Avatar
ninjosh97
AKA: Josh
Thanks everyone!
Josh H.
4 FLL Seasons
Unread 19-01-2014, 14:08
Where did you read about the continuous methods? Sounds like there's something that should be updated.
