Go to Post Every time i look at my watch and see 3:65 o'clock I always thing, darn i gotta get a new watch... - Kyle [more]
Unread 19-01-2014, 14:13
JamesMcD_4505 JamesMcD_4505 is offline
FRC #4505
JamesMcD_4505 is an unknown quantity at this point
Getting SmartDashboard to Update Continuously
Hello Chief Delphi,
Our software team is trying to find a way to get SmartDashboard to update continuously. We want to make sure that when we change a value on SmartDashboard, it actually updates within the code (in a command based system). What is the best way to go about doing this?
Thanks,
Team 4505.
Unread 19-01-2014, 14:20
Re: Getting SmartDashboard to Update Continuously
Network Tables makes sure that the values are always available in the robot code, so that all you have to do is do a get.
Unread 19-01-2014, 14:51
FRC #4505
Thanks Mr. Ross,
Would we need to create a separate class in our command based system, or can we just insert this into any pre-existing class?
Thanks again,
Team 4505.
Unread 19-01-2014, 17:02
You can call SmartDashboard.getNumber from anywhere.
Unread 01-02-2014, 00:37
CreativeName55 CreativeName55 is offline
FRC #2729 (Storm Robotics)
CreativeName55 is an unknown quantity at this point
SmartDashboard also has properties, such as integerproperties, which allow it to rather easily take in and edit values sent to it by the user. They're a tad more confusing than network table at times, but can be edited in a popup, rather than cluttering the dashboard
Unread 01-02-2014, 23:53
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Keep in mind that NetworkTable values can have a latency of ~200ms between the dashboard and robot. For most stuff you won't notice this, but you can't rely on it for high-frequency stuff.
I code stuff.
