Go to Post I wonder if the kit motors run counterclockwise in the Southern Hemisphere? - Gary Dillard [more]
Unread 18-01-2014, 16:01
hagen876 hagen876 is offline
FRC #0876
hagen876 is an unknown quantity at this point
No cRIO communication!
Hey, on the 2014 labview software, there is a cRIO imaging tool, that we cannot get to connect to the 4 slot cRIO. We changed all the IP addresses to the correct ones (computer to 10.8.76.5 or .6), we have a full battery, tried 4 computers, tried hooking through the game piece and directly, were out of options.
I have read many of these problems, but none have worked. We can get to the game piece with the internet and entering the IP address, 10.8.76.1, but not the cRIO.
Any ideas would be greatly appreciated!
Unread 18-01-2014, 18:56
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: No cRIO communication!
Is your computer's IP address set correctly? The easiest way is to launch the FRC Dashboard and have it automatically configure your local network with your team number.
Unread 18-01-2014, 19:02
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
Did you disable the computer firewall?
Unread 18-01-2014, 22:57
What do you mean when you say "game piece"? I'm pretty sure you aren't talking about the Sportogo exercise ball. The D-Link router would be my first guess, except you're talking about getting to it with the internet, which doesn't make sense to me.
Your computer's IP address sounds right. The two big things to check are 1) make absolutely completely certain that you don't have a firewall running, and 2) make absolutely completely certain that the only network adapter enabled on your computer is the one connected to the cRIO.
Unread 19-01-2014, 12:09
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Are you able to ping the cRIO? The IP address is 10.xx.yy.2.
Unread 19-01-2014, 14:57
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
We had a multitude of cRIO imaging problems and here are the solutions that were recommended:
-Use a crossover cable and go directly to the cRIO (though it should be an Auto-MDIX port)
-Connect through a switch
-Change the IP of your laptop to 10.xx.yy.8 instead of .5 or .6
-Power cycle EVERYTHING
-Hold the "Reset" button for five seconds (the status light will change to solid orange) then wait for it to tun off, then hold the "Reset" button for five more seconds. This causes the cRIO to do an IP Reset. Then open command prompt and type "ping 0.0.0.0" and if that doesn't work, switch your laptop's IP address to 169.254.0.1 and then open your cRIO imaging tool and see if it can now detect your device
-If all else fails, try a new laptop because that has solved problems for us in the past even though they're exactly the same... Who knows why?
Hope this helped, FIRST Team 1024
Unread 19-01-2014, 15:11
Ivan_Yuri's Avatar
Ivan_Yuri Ivan_Yuri is offline
Forged Finely From Francium Fires
AKA: Nick Verstrate
FRC #3335 (Cy-Ranch Cy-Borgs)
Team Role: Marketing
Ivan_Yuri is an unknown quantity at this point
Smile Re: No cRIO communication!
Our team's head programmer had two things to bring to the table when I asked him this for you; both were problems that we had ourselves, so see if it may help!
Method 1) Make sure your firewall is down, as this can hamper communications;
Method 2) Are your laptops running Windows 8? Even the most up-to-date programs that FRC uses for the cRIO's aren't compatible in the slightest with Windows 8, to the point that you can't even connect to the cRIO from a computer with Windows 8. If you're using a computer with that OS, then to be frank, you're plum outta luck with that one...
I hope for your and your team's sake that it's just a firewall issue, but if it is because of possible Windows 8 incompatibility, then I wish you luck for finding a fix to the problem. Keep us all here informed if any of that fixes it or not, I hope you can do so soon!
Best of luck out there!
Unread 19-01-2014, 15:27
I'm not sure where the Windows 8 info is coming from. Windows 8 was explicitly tested during development and beta program. Can you point to any documentation or experience that leads you to that conclusion?
Greg McKaskle
Unread 19-01-2014, 18:47
FRC #0876
Thanks guys, we did a lot of those things, but I read a few new things I can try. I am on windows 8.1, but we used 4 different computers, 3 with windows 7. Thanks again!
