Go to Post It all seems like good clean fun until someone drops a Phaeton 65 meters. - Rick TYler [more]
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Unread 15-01-2014, 00:05
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Build Blitz Robot Reveal - Team JVN
What did team JVN use for surgical tubing on the launcher (and where do you get it)? The tubing we've been prototyping with has been less than effective.
Unread 15-01-2014, 09:22
Aren_Hill's Avatar
Build Nifty Things
Just black Latex tubing from McMaster.
http://www.mcmaster.com/#latex-tubing/=q9fexw
I think that stuff was 5234K46 (1/2" OD, 1/4" ID)
A guy who likes robots.
Unread 15-01-2014, 11:16
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I don't remember seeing this anywhere so I figured I'd ask - what material are the ball holding posts made from and is there a vendor where we could pick up a few?
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 15-01-2014, 15:51
Aren_Hill's Avatar
Build Nifty Things
Ryan,
Those are chunks of McMaster part# 87235K81
We just shoved it over some standoffs made from 1/2" HEX stock.
-Aren
Unread 15-01-2014, 16:00
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
What material did you use for those flexible black rods?
Unread 15-01-2014, 16:20
Aren_Hill's Avatar
Build Nifty Things
1/2" Black Delrin rod, but many things will work, we just happened to have it on hand.
Unread 15-01-2014, 17:35
Dan Oelke Dan Oelke is offline
FTC #5926 (The Things)
FRC #3023 (Stark Industries)
Dan Oelke is an unknown quantity at this point
I love the choo choo. What I don't understand is how you did the pivoting joint between the parts of the linkage. Guessing from the video looks like about 1/4" x 1/2" bar stock and I just don't see how you can do a pivoting link in that 1/4" thickness.
Can you give me any pointers or diagrams or ?? about how that joint is put together.
Thanks!
Unread 15-01-2014, 19:20
Aren_Hill's Avatar
Build Nifty Things
Thanks!
In our case I essentially made a shoulder bolt that tightened into the first strap and captured a bushing which the other strap spun on, I "handcrafted" the attachments due to limited time and not having shoulder bolts of the proper size on hand.
Unread 16-01-2014, 16:13
andboyer andboyer is offline
FRC #4984
andboyer is an unknown quantity at this point
Can someone add a little more detail? The video doesn't explain the details of the release.
Unread 16-01-2014, 17:40
Look more closely at the bar link that's attached to the cam.
Notice how the protrusion on the cam catches that bar as the catapult is being pulled back.
Notice how, in the video, the cam stops before that bar goes over-center.
To release, the cam is rotated further (in the same direction it was turning before) until the bar goes over-center. At that point, the tension pulls the bar off the protrusion and launches the catapult.
Unread 18-01-2014, 23:34
Willyspu Willyspu is offline
AKA: Jim
FRC #2144 (Gators)
Willyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the rough
On the opposite side of the 84t gear there is a pointer and switch, is this a encoder to hold the motor in the ready position? If not, what is it's purpose?
Thanks,
Jim
Team 2144
Name:	Delphi Question.png
Unread 19-01-2014, 00:35
Aren_Hill's Avatar
Build Nifty Things
Thanks,
Jim
Team 2144
This single switch controls the entire retract and fire mechanism, since the cho cho only rotates once per cycle it is just as easy as running till the switch is hit, then stopping.
When the fire button is pressed the shooter pulses forward for .25 seconds, waits .25 seconds for the action to cease, then runs until the switch is hit again.
I have yet to see a simpler method.
Unread 19-01-2014, 02:02
AKA: Jim
FRC #2144 (Gators)
What type of switch is this? Is it an on/off, position switch or encoder?
I am a mentor and just trying to figure out how you held the motor in position until you were ready to fire the next shot.
Thanks!
Jim
Team 2144
Unread 19-01-2014, 02:07
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Thanks!
Jim
Team 2144
The switch is just a limit switch that tells the system when to stop turning the motor. What actually stops the axle from backdriving is the wrench in that picture. It is just a standard ratcheting wrench, and you can see it in the picture right below the pointer.
Team 4488 - Mentor 2013-2016
Unread 19-01-2014, 16:25
thesuperfez thesuperfez is offline
FRC #5254
thesuperfez is an unknown quantity at this point
Question Re: Build Blitz Robot Reveal - Team JVN
I have a question about the piston used to extend the rolling arm that collects the ball. We are a rookie team and are unsure of the sizing of pistons. Does anyone know the bore size and stroke length used for this bot in particular?
