Go to Post Yeah, if we didn't have robots then we could concentrate on all that outreach stuff! - marshall [more]
Unread 19-01-2014, 16:29
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Re: Quick Exhaust Valves - Illegal !?!?
Originally Posted by MrBasse View Post
I'm curious to hear the answer as we have used a 90 degree fitting with no tubing to vent to atmosphere while using gravity to return the cylinder for the last two years. We used it on our ball pickup in 2012 and our climbing arms and disc dump in 2013. Both years we passed inspection at two districts and MSC.
Also, if you put the opening in the cylinder out of the way of a place where dirt and dust can accumulate, there is very little risk of pickup up any debris.
We have done it for years this way also with no issues. I read through the pneumatic rules and did not see anything pertaining to this.
Unread 19-01-2014, 16:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
There is no rule which states that the open ports of a cylinder must be attached to the solenoid, which means that there is no reason venting directly to the atmosphere is illegal.
If it were made illegal via a new rule, I'd be pretty upset. We are working on a design that uses pneumatics and hasn't been seen in FIRST (or at least in the many designs I've seen or studied from 2008, 2010, or 2014). It's pretty simple, but relies on the pressure venting directly to the atmosphere. We could possibly overcome a ruling, but only by moving to more expensive solenoid valves.
GitHub
Unread 19-01-2014, 16:38
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
my thoughts exactly
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 20-01-2014, 00:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Which is why I can't understand why quick exhaust valves are illegal. Perhaps it is the difference in venting near-atmospheric pressure to atmosphere, as opposed to venting 60 PSI to atmosphere? Still, I don't see the danger in it.
Unread 20-01-2014, 09:05
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I view the new solenoid valve rule as a positive step. My impression is the GDC is keeping the pneumatics restricted to keep the robots safe & to simplify the inspection process.
This was done in 2010. No comment on if it would be legal in 2014
Posted by 2010FRC0476 at 01/25/2010 10:52:27 am
Can we use plug valves, Parker model # PV609-2 as allowed in Rule R72, instead of
solenoids to activate and exhaust pneumatic cylinders? We would rotate the plug valves using
pneumatic 90-degree actuators and a custom-made bracket between the pneumatic actuator
and the plug valve handle. Or we would turn the plug valves using HS322-HD servos or the
Denso window motors.
Re: Plug Valves Instead of Solenoids
Posted by GDC at 01/28/2010 12:03:45 am
There is no rule that would prohibit this.
Unread 20-01-2014, 11:33
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
my thoughts exactly
TEAM 1946-Tamra
Unread 21-01-2014, 07:31
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Has anyone run that by Q&A? Ya never know...
There is no rule against this, and unless they create a rule outlawing single acting cylinders (which is what this would be) there won't be. I cannot imagine the GDC suddenly outlawing more than 50% of the available cylinder on the market.
Former Mentor Team 1771
Former mentor Team 4509
Unread 21-01-2014, 12:58
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I wouldn't assume that. The GDC outlawed almost all of the available wheels on the market in 2009. (Not that I expect them to do that again...)
Unread 21-01-2014, 13:07
martin417's Avatar
AKA: Martin Wilson
Yes, as part of the game, and at the beginning of the season.
Unread 23-01-2014, 15:57
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Forgive a ridiculous question, please --
What type of device, generally, is that which is described as a "pressure vent plug" in Figure 4-15 in the manual? (http://frc-manual.usfirst.org/viewItem/181#4.10)
This is what we all use to vent the system of pressure and does not appear to be among those items listed in R77-F.
What am I missing?
Derp -- I'm missing part B.
So, then, the question becomes -- what makes this valve functionally different from a ball valve / quick release valve?
--Madison--
...down at the Ozdust!
Unread 23-01-2014, 16:25
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
What am I missing?
Functionally, it is just like a ball valve. Except the rules call it a vent valve with the functional intent to dump all air out of the system. At least that is how I read the rules & Q&A comments.
The real question becomes how do you isolate the systems you use an off board compressor since you are apparently not allowed to use valves?
I really don't envy the GDC in all this.
Unread 23-01-2014, 16:54
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
I'm easily confused and think we're mixing names of devices. Here're some references:
Pneumatic Valve Types
A GUIDE TO UNDERSTANDING PNEUMATIC
DIRECTIONAL CONTROL VALVES
Wikipedia: List of valves
McMaster Carr
Unread 23-01-2014, 20:00
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
For the questions above here's a good video explanation
http://www.youtube.com/watch?v=X5SVF7TV8w4
As for my two cents, I agree. I think the GD is unnecessarily limiting with pneumatics. I don't agree that they want to "keep the bots simple" or make it easy for inspection. IF that's the case then I think its wrong and goes against the good portion of what FIRST is about.
This is one area I think FIRST could improve. Remove some of the restrictions that limit legitimate design ideas. Safety can still be maintained. Its done everyday it can be done in a first event.
Unread 24-01-2014, 23:11
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Originally Posted by Christopher149 View Post
Since our prototype is currently using a fitting-less downstroke, I went ahead and asked.
Looks like we have a reply:
Q. Is there any rule that prevents a port on a pneumatic cylinder from venting directly to atmosphere, without any fitting or tubing, so that only one direction of motion is powered?
2014-01-19 by FRC0857
A. No.
So this means venting to the atmosphere is legal. Now we know our shooter is legal!
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 24-01-2014, 23:18
DavisDad's Avatar
MechE
3175student17- thanks for the information; much appreciated!
