Go to Post There's a balance to it all, when the engineers guide the students, and both cooperate to build a robot. There can be no better way then when both sides are in cooperation - the true spirit of FIRST. - Jim McGeehin [more]
Unread 19-01-2014, 17:28
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Re: Robot Oriented vs. field Oriented
One thing teams have done to mitigate this is to have a button on the joystick that the driver can press to zero the gyro whenever the bot is in the zero position (usually facing straight downfield).
Something that our team does is to click the B button on the driver's gamepad before the match starts but after the robot is placed on the field, and this zeros the gyro. We usually try to do this as late as possible, but it is very effective in eliminating drift. Something else that you could do is to turn on the robot after it is placed in its starting configuration so that the gyro doesn't change when teams position the robot.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
