Go to Post I can't wait to be one of those old kids who can say "Yeah, I remember the days before districts." and then watch the kid's eyes widen when I explain the days of regionals.. - rachelholladay [more]
Unread 19-01-2014, 17:47
blanketboyjo blanketboyjo is offline
FRC #0687
blanketboyjo is an unknown quantity at this point
File IO without overwriting file
Hi, so I am trying to make the CRIO print out to a text file that I can read through ftp. I have it working to make the file, but everytime the code runs it overwrites the file, is there any way to make it so that new lines are added to the existing file?
PrintStream writer;
DataOutputStream myFile;
FileConnection con;
try {
con = (FileConnection)Connector.open("file:///test.txt", Connector.WRITE);
con.create();
myFile = con.openDataOutputStream();
writer = new PrintStream(myFile);
} catch (Exception e) {
writer.println("Message");
Unread 20-01-2014, 08:03
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: File IO without overwriting file
Try
writer.append("Message");
Unread 21-01-2014, 00:58
FRC #0687
I tried that but it says that append() is not a function of dataoutputstream. Is there anything else I can do?
Unread 21-01-2014, 11:44
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
What if you tried something like this?
public void appendToFile() {
    FileConnection file;
    OutputStream out;
    PrintStream writer;
    try {
        // Open file for writing
        file = (FileConnection) Connector.open("file:///test.txt", Connector.WRITE);
        out = file.openOutputStream(Long.MAX_VALUE);
        writer = new PrintStream(out);
        // Append data to file
        // Close file connection
        writer.close();
        out.close();
        file.close();
    } catch (IOException ex) {
        // Handle exception
        ex.printStackTrace();
The parameter passed to openOutputStream() specifies the offset position for writing to the file. Since the offset (should be) larger than the file size, it moves it to the end of the file, allowing you to append to the file instead of overwriting it.
Source: http://myossdevblog.blogspot.com/200...a-me-j2me.html
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 25-01-2014, 19:06
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
I've been getting IO exceptions whenever I try anything along the lines of
OutputStreamWriter writer = new OutputStreamWriter(connection.openOutputStream(Lon g.MAX_VALUE));
or index out of bounds exceptions when I try:
writer.write(entry, (int)connection.fileSize(), entry.length))
(notably, for a file with about 15 characters in it, fileSize is returning 4831838208. That doesn't seem healthy or right.)
Has anybody been able to append to a file successfully on the robot?
Unread 25-01-2014, 20:13
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Originally Posted by blanketboyjo View Post
PrintStream writer;
FileConnection con;
try {
use Connector.Read_Write
try something like this
Connection conn = Connector.open(String fileName, Connector.READ_WRITE);
FileConnection fc = (FileConnection) conn;
if (!fc.exists()) {
fc.create();
OutputStream os = fc.openOutputStream(fc.fileSize());
After opening the file with the above code snippet if you are going to write something to the file then it will append at the end of the file content
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 27-01-2014, 01:42
FRC #0488
Yeah, that's code that I would very much expect to work.
I am opening the fileconnection using
FileConnection c = (FileConnection) Connector.open(PATH, Connector.READ_WRITE);
and I have tried
OutputStreamWriter writer = new OutputStreamWriter(c.openOutputStream(c.fileSize()));
but that triggers an IO exception.
Have you made that code work on the cRIO? I have similar code that works on a PC, but something about the cRIO seems to be causing a problem...
Unread 27-01-2014, 03:46
Controls Engineer
AKA: Kevin
Yes, what is the need to use the OutputStreamWriter class vs outputstream as in the example shown?
Do you know which IO exception is being thrown? Maybe we can track down the problem that way
simplistic approach:
try {
  throw new FileNotFoundException("This is an error message");
} catch (FileNotFoundException e) {
  System.out.println("File not found: " + e.getMessage());
} catch (EOFException e) {
  System.out.println("End of file reached: " + e.getMessage());
} catch (IOException e) { // catch all IOExceptions not handled by previous catch blocks
  System.out.println("General I/O exception: " + e.getMessage());
  e.printStackTrace();
Unread 27-01-2014, 11:45
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
https://github.com/Team4334/atalibj/...TextFiles.java
I've tried dealing with this problem multiple times. Ended in just hacking a solution together.
If anyone's solutions end up working on a cRIO (and after reboots too!) - please let me know or submit a pull request. That'd be awesome.
All opinions are my own.
Unread 27-01-2014, 11:54
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
What about creating a new log file each time? That's how things are handled with the server production systems I work with - each log file has a timestamp as part of the file name to help prevent overwrites.
I'm not sure how the clock works on the cRIO or what level of access we have towards getting a standardized timestamp, but there are other options as well. For example, you can have each log file generated with an incrementing numerical value (1.log, 2.log, etc). Keep the current value in a config file (log.config). When the program starts up, it reads the config file, increments by 1, writes the new value out to the config file (overwriting the old value) and creates the log file using that value.
This has the added benefit of giving you a separate log file for each run, which will help you keep everything organized.
2016: Lake Superior WFFA
Unread 27-01-2014, 13:26
Controls Engineer
AKA: Kevin
I don't want to get off topic but,
Originally Posted by Jon Stratis View Post
I'm not sure how the clock works on the cRIO or what level of access we have towards getting a standardized timestamp, but... .
Unfortunately, the clock gets reset to Jan,1 1970 everytime the cRIO is started.
In the past I have played with reading system time from the Driverstation system clock and sending that over to the cRIO through the dashboard.
In Java there is no way to overwrite the system clock on the cRIO because the JRE doesn't allow access to the clock, you could do it with a JNI system call but I never went that far.
If you don't care about updating the system time on the crio, you could simply get a timestamp from the driverstation on robot startup and keep it in a variable and use that for time stamps, and use System time as a couter to count time since your "time sync".
Hope this helps,
Kevin
Unread 27-01-2014, 13:41
The 8-slot cRIO has a battery backup for the RTC, but the 4-slot does not. See https://decibel.ni.com/content/message/33390#33390.
Unread 28-01-2014, 13:20
FRC #0488
If we can't get a generic append function working, we'll probably go with multiple incrementing log files, but there are some downsides:
-Since the robot can terminate unexpectedly, we have to flush our buffer fairly often to make sure we don't lose data due to a power failure or unexpected reboot
-Too many small files is a pain to read and process, so we would need to find a balance
I'll try to get more detail about our current IO exception (also, does anybody else have that problem where FileConnection.fileSize() returns an enormous number?), and if that doesn't work out, implement a solution like joelg236's. We already had some code that buffered about 7.9k worth of logs before flushing to disk, so we shouldn't be spending too much time on IO.
