Go to Post I would like to complain about the game as well. Complain, complain. - Monochron [more]
Unread 19-01-2014, 18:37
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
VEX Ball Shifting into Neutral
Okay I know there is a big thread about this but I was a bit afraid that my post would get lost since there are so many posts, so I am posting here. My team and I had the idea of putting a ratchet on the low gear of the gear box so while in that gear it could not back drive without putting stress on the CIM motors. Then the high gear would be made a neutral gear as described in the other thread. This would make it so the pawl would not have to be pulled out just the sifter would shift to neutral. What my question is when the low gear has so much torque on it will the sifting mech be damaged or hurt in any way when it is pulled into neutral?
Unread 19-01-2014, 19:57
Dr.Gusta's Avatar
Team Role: CAD
Re: VEX Ball Shifting into Neutral
I just cleaned up the CAD a bit and rendered out a few views for you guys to see what I am talking about.
ID:	15876  Click image for larger version
ID:	15877  Click image for larger version
Unread 19-01-2014, 20:04
Aren_Hill's Avatar
Build Nifty Things
No, mechanically the Ballshifter construction is very well suited to releasing under high loads, due to the geometry of the shifting mechanism the shifter shaft sees a much smaller load and may be pulled free with much lower amounts of force than DOG shifters.
A guy who likes robots.
Unread 19-01-2014, 20:12
Dr.Gusta's Avatar
Team Role: CAD
Awesome thank you for the reply I really appreciate it.
Unread 19-01-2014, 23:38
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
you can also use a 1/2" ratchet wrench on the output shaft to achieve the same non backdrive characteristic, but with much much less work.
Unread 19-01-2014, 23:40
Dr.Gusta's Avatar
Team Role: CAD
The only problem we ran into with that is that if we put it on the final output it will never be able to fire unless we could disengage the wrench some how.
Unread 19-01-2014, 23:47
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
You need to put the rachet somewhere before the neutral, so an extended shaft is needed, which calls for the wcp gearbox, which has dogs (o noes, dogs!). Fabricating a custom longer shaft could also work, may need some new bearings.
donkehote's Avatar
AKA: Kevin
FRC #5031
very good point... didn't think about that.
looking at the cad, you could extend the first shaft (the 3/8 hex one with the gear the 3 cim pinions drive) using a 3/8 hex bearing on the case instead of a round one. then you could put the wrench on the outside of the case. would just need something to keep the shaft from walking out of the case.
other than that, the solution you have there should work, don't see why not.
Unread 20-01-2014, 03:17
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
You could also try removing the gears for the low gear stage and put the wrench through a similar hole to what you have now replacing the smaller gear
2016: FRC 865 Mentor
Unread 20-01-2014, 23:10
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
We considered what you have and thought about making the cogs of the ratchet much less steep--almost perpendicular to the center. With a small pneumatic cylinder to activate the pawl you could easily control it.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
