Go to Post Who has time for boredom? - Dr Theta [more]
Unread 19-01-2014, 20:43
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
Irregular Drivetrain
So this year, my team is working on a 6wd drop center drivetrain. While working on it, we realized that the belts we had were not long enough to make the distance from the back wheels to center wheels and front wheels to center wheels the same. It is probably around 6 inches of difference. So, our question is this: How big of a deal is this difference in regard to turning?
Unread 19-01-2014, 20:44
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Irregular Drivetrain
Are you going to move your outer wheels towards center to allow the belts to fit, are you going to run your outer wheels without any power? What are the dimensions of your drive base? Have you considered ordering longer belts? Running chain instead of belts?
Unread 19-01-2014, 20:46
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
You can use a combination of weight distribution and the irregular drivetrain to make your robot turn quicker/slower depending on what your goal would be.
So no, it just means that your turning will be a bit different.
EDIT: With given information.
Currently a student at the University of Toronto - Mechanical Engineering
FRC 781 alumni
Unread 19-01-2014, 20:52
zachrobo1's Avatar
AKA: Zach Cloud
We do want all wheels to be powered, so the back wheels are moved outwards a bit. We are using a modified (30" long 21" wide) 2013 Kitbot Chassis (Don't worry, nothing was built before Kickoff). We are considering using longer belts/chain, but were going to figure out if it made a difference before we placed an order.
Unread 19-01-2014, 21:33
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
What are the dimensions of your turning base? The only issue that presents itself with shortening the wheel base but keeping the same drop is that an 1/8" drop with a shorter wheel base is some unwanted rocking in the base. How much distance is there between the middle wheel and both outer wheels, and how wide is the distance between the two middle wheels? More than likely you should be fine with a 1/8" drop. You can also mitigate any rocking issue with clever weight distribution and CG manipulation.
One thing you may want to look into is instead of dropping the center wheel 1/8" of an inch, try raising the wheels that are farther out by 1/8", and set the weight distribution such that the CG is on the wheels that are touching the ground at all times.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
