Re: Relay Outputs on Digital Side Car Not Working
If the Relay LEDs are still not lighting up, then the code & firmware need to be checked.
This is more for others you may read this later... If the Relay status LEDs were lighting up (and the Spike still wasn't responding), then I wouldn't suspect code or firmware any longer. Just make sure only the Relay green or only the red come on at a time (assuming that you are using the Spike to control a motor). I'd next test the Relay output pins with a multi-meter to see if you see power to match the LEDs. 0v on a pin if the corresponding LED is out, 5v if the corresponding LED (red or green) is lit. If that passes, then work your way towards the Spike. Plug a PWM cable into the appropriate Relay, then use the multi-meter to test the far end of the PWM cable. If you get a signal all the way out there, then the Spike is the remaining issue. Connect it and the Spike LED should show orange when it has 12v power, otherwise the color should match the DSC's Relay LED. Last edited by Mark McLeod : 19-01-2014 at 21:13. |
Another way to double check things is to set the DS to test mode. In your dashboard, click on the test tab, and scroll to verify the relay is listed. You can select the relay and press the momentary button to turn on the relay.
Greg McKaskle |
No kidding? Nice tip...We will try that.
We're having the same issue, but we've found a temporary solution! The "Long" cRIO (8 slots) test board we have was having the issues with not running the relays. Our "Short" cRIO (4 slots) test board uses the relays without issues running the same code. (We're using java)
I don't have any clue why this happens, but my best guess at the moment is that the long cRIO is anti-relay... |
Oh I forgot to follow up.
First of all, the "TEST" mode in the new driver station, is AWESOME! Kudos to the NI team for making that. I was pressuring our software team to make a custom dash board that has a maintenance screen that we can view and "force" I/O points, but the TEST mode does all this for the teams. Thank you for this. Using test mode, we was able to "force" the relay output points on and off. This proved that everything work electrical. So it was a software problem. After the software team reviews future, I was told the problem was the START VI was moved out of order. I believe it was before or after the references or something like that. Once they corrected that problem in the software, the compressor and all relays started working again. They did confirm they had version 52. The biggest take away was using the new TEST mode in the driver screen. That was a nice tool. Thanks everyone for your input. Problem solved with us. |
We were going to store our device references in global variables instead of the Refnum Registry, but since Test uses the registry we decided we had to use it too. |
