Go to Post MAKE SURE THE BATTERY DOES NOT FALL OUT - magnets [more]
Unread 19-01-2014, 23:21
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Winches and alternatives to the modulox lunchbox?
Our team has been pretty stuck this year on winches and on how to pull back a catapult. We originally wanted to go for a non-backdrive winch/gearbox with a clutch, that way we have total control over the power of the shot. We have decided that this is not necessary/reasonably possible, so we decided that we wanted to use the modulox lunchbox like in the robot in 3 days video. Of course they are out of stock now, so that is no longer an option.
So, Can someone please recommend an alternative to the modulox lunchbox, like the one used in the robot in 3 days video?
Unread 19-01-2014, 23:37
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Re: Winches and alternatives to the modulox lunchbox?
We are using a modified Gen 1 Shifter but i believe those are out of stock/not made anymore. You could base it off a super shifter of a tough box. Tough box obviously needing a secondary release mechanism or integrate a shifter mechanism...a fair amount of machining.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 19-01-2014, 23:42
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
You can check out my teams solution using the VEX ball shifter. I have some basic CAD posted here on CD.
http://www.chiefdelphi.com/forums/sh...hreadid=124927
Good luck to you
Unread 20-01-2014, 01:06
IVAN IVAN is offline
FRC #2429
IVAN is on a distinguished road
at 2429 we were able to get a andymark sonic shifter to do the neutral and the one way drive. We did this by 1)removing the both of high speed gears from the cluster 2) putting in a pvc spacer where the original first stage gear used to be on the motor input gear 3) we used a craftsmen cross force ratcheting wrench in place of the brass that was being used as a spacer on the top of the input shaft. I will post pics as soon as i can
Unread 20-01-2014, 02:33
ice.berg's Avatar
ice.berg ice.berg is offline
Strategy Mentor & Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
I would look at what team JVN did for the build blitz and maybe combine some of their features into yours. For the non back drive quality that they needed they used a 1/2 in ratcheting wrench and put it around a 1/2 hex shaft on the gearbox they were using. You could easily implement this using a touch box or a shifter box ex. ball shifter or AM Supershifter. Then you have to decide on how you release the cable attached to your shooter. This would be a neutral gear so to speak.
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
Unread 20-01-2014, 05:52
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
What he said. The choo-choo works well for us (so far) and we are working on some tweaks.
If you want to drive a winch, and have another release mechanism in mind, you might take a look at this. Low cost hypocycloidal gears, packaged like a large wrench. Pretty cheap at Harbor Freight. The motor shown is not legal any more, but several good alternatives are out there including PG71 and Versaplanetary.
Richard Wallace
since 2003
Unread 20-01-2014, 19:21
FRC #3734
How does the choo choo mechanism release it's self?
Unread 20-01-2014, 20:10
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Its a bi-stable mechanism. Once you pass a tipping point, the mechanism releases itself.
Because there is a hard stop for the first part of the linkage on the rotating wheel, it can pull down the catapult. Eventually this hard stop no longer prevents the linkage from moving upwards, and the surgical tubing pulls it.
http://youtu.be/Gm96S8gdhR0?t=3m8s
If you look at this video, the screw catches the first part of the linkage, allowing the catapult to be wound back. They cut away just before launching, if you continue rotating the gear further, the direction of the force on the linkage switches from against the screw to free allowing the linkage to snap and release.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 20-01-2014, 21:30
http://www.chiefdelphi.com/forums/sh...6&postcount=25
Also see attached stick-figure sketch.
Unread 20-01-2014, 21:55
isaac.walz's Avatar
isaac.walz isaac.walz is offline
FRC #2080
isaac.walz is an unknown quantity at this point
We somehow got our hands on a lunch box but as an alternative to adding a shifter column we just cut down a spring and placed it between the two gears on the 3/8 shaft. A mini cylinder will disengage the gear and the spring will return it. It was a very cost saving way of doing it
Unread 20-01-2014, 23:24
FRC #3734
Thank you this helped a lot! Also, tell Dagney her cousin sad hi
Unread 20-01-2014, 23:27
FRC #3734
Thank you very much! This clarified a lot and now the shoe thing makes sense! Are there any existing equations out there to help figure out the proper lengths of each component based on the total amount of pullback required?
Unread 21-01-2014, 22:45
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
The Lunchbox is back in stock!
It was out of stock due to the 1/2" Hex Shaft Collars which are not needed for the winch assembly. This part is not supplied by iR3 but we do keep a small inventory and will be sending this to AM as reserves if needed. You could also order the specific parts required for this assembly without a problem.
We apologize for this temporary inconvenience it was certainly unexpected.
/edited with updated information...
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 22-01-2014, 13:31
FRC #3734
Thanks for letting us know! This is definately good news to our team. Also, happy birthday!
