Go to Post 256:1 gear reductions provide surprisingly little torque once the gears have failed. - Kevin Sevcik [more]
Unread 20-01-2014, 00:07
tech2077 tech2077 is offline
AKA: Matthew Skolaut
FRC #3847 (Spectrum 3847)
tech2077 is an unknown quantity at this point
SerialPort viOpen error
I was trying to run the posted code in order to test out the serial port on our cRIO. The code faulted with a null pointer error due to the serial resource not being initialized and returning the error "VI_ERROR_RSRC_NFOUND in function viOpen"
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.SerialPort;
import edu.wpi.first.wpilibj.visa.VisaException;
public class RobotTemplate extends IterativeRobot {
    public SerialPort serial;
    public void robotInit() {
    public void autonomousInit() {
    public void autonomousPeriodic() {
    public void teleopInit() {
        try {
            serial = new SerialPort(115200);
        } catch (VisaException ex) {
            System.out.println("Error to initialize serial port at 115200 baud " + ex.getMessage());
    public void teleopPeriodic() {
        try {
            serial.print("test");
            System.out.println(serial.read(1));
            System.out.println("Error");
Unread 20-01-2014, 11:31
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: SerialPort viOpen error
        try {
        try {
The Java SerialPort implementation seems to be buggy, I don't think that the issue found here http://firstforge.wpi.edu/sf/go/artf...3699545405 50 has been fixed yet.
It may also be useful to check the following
  1. State of the Console Out switch (You don't need it on if you're trying to do something like interface with a sensor over the serial port)
  2. No CAN plugin installed if you're not trying to use CAN (They take control of the serial port)
  3. Correct cable (Some implementations require a special DB9 cable known as a null modem cable)
Unread 20-01-2014, 11:36
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
1 and 2 are not the problem, I reimagined the cRIO for this setup with him last night and made sure to remove the CAN drivers and turn off Console Out.
We saw that bug, but the fix was attached in May and should have been rolled into the 2014 release, I would think. Plus this isn't the same error as that one.
Unread 22-01-2014, 14:02
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
        try {
        try {
I'm working with a few teams who are using the nav6 IMU, and they are running into this problem too.
It's sporadic.
SerialPort settings we use are 57600, 8, N, 1
The nav6 sends a stream of 30-40 bytes packets at about 20-50Hz rate, so a stream of bytes is arriving when the serial port is opened.
[cRIO] edu.wpi.first.wpilibj.visa.VisaException: VI_ERROR_RSRC_NFOUND in function viOpen
[cRIO] at edu.wpi.first.wpilibj.visa.Visa.assertCleanStatus( Visa.java:151)
[cRIO] at edu.wpi.first.wpilibj.visa.Visa.viOpen(Visa.java:6 3)
Here's a note on the error:
"...there doesn't seem to be any consistency with when the error occurs. Occasionally it would happen after a few times of sending new code to the robot and sometimes it would happen after I had just powered on the robot. I wasn't able to find anything that seemed to be a specific trigger. I was typically able to fix it by leaving the robot powered off for a period of time and then powering it back on."
[Side Note: If possible, if the Java SerialPort class is being modified, can the setReadBufferSize() method please be made public?]
Unread 22-01-2014, 16:47
AKA: Brad
#0190 ( Gompei and the Herd)
Check this thread:
http://forums.usfirst.org/showthread...t-viOpen-error
Brad
Brad Miller
Robotics Resource Center
