Re: Winches and alternatives to the modulox lunchbox?
I would look at what team JVN did for the build blitz and maybe combine some of their features into yours. For the non back drive quality that they needed they used a 1/2 in ratcheting wrench and put it around a 1/2 hex shaft on the gearbox they were using. You could easily implement this using a touch box or a shifter box ex. ball shifter or AM Supershifter. Then you have to decide on how you release the cable attached to your shooter. This would be a neutral gear so to speak.
What he said. The choo-choo works well for us (so far) and we are working on some tweaks. If you want to drive a winch, and have another release mechanism in mind, you might take a look at this. Low cost hypocycloidal gears, packaged like a large wrench. Pretty cheap at Harbor Freight. The motor shown is not legal any more, but several good alternatives are out there including PG71 and Versaplanetary. |
How does the choo choo mechanism release it's self? |
Its a bi-stable mechanism. Once you pass a tipping point, the mechanism releases itself.
Because there is a hard stop for the first part of the linkage on the rotating wheel, it can pull down the catapult. Eventually this hard stop no longer prevents the linkage from moving upwards, and the surgical tubing pulls it. http://youtu.be/Gm96S8gdhR0?t=3m8s If you look at this video, the screw catches the first part of the linkage, allowing the catapult to be wound back. They cut away just before launching, if you continue rotating the gear further, the direction of the force on the linkage switches from against the screw to free allowing the linkage to snap and release. Last edited by Trent B : 20-01-2014 at 20:14. |
#7
We somehow got our hands on a lunch box but as an alternative to adding a shifter column we just cut down a spring and placed it between the two gears on the 3/8 shaft. A mini cylinder will disengage the gear and the spring will return it. It was a very cost saving way of doing it
#8
