Go to Post So, the game hint is there is no game hint. - tindleroot [more]
Unread 19-01-2014, 23:21
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: help repairing 2014 game pieces
Originally Posted by MrForbes View Post
The web page says the bladder is made of PVC. Isn't that what the pool liners are made of?
If made of PVC, maybe PVC pipe cement would work
P.S., tried t bicycle tire patch today, no luck
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 19-01-2014, 23:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I would rather try a pvc patch kit, than PVC cement. The cement might dissolve too much
Unread 20-01-2014, 07:25
Gdeaver Gdeaver is online now
FRC #1640
We used a bicycle repair kit and so far it is holding up. Very small hole.
Unread 20-01-2014, 07:48
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
Pool liners are made of vinyl. The glue and patch material used will stick to PVC but it is the expanding of the ball that might make it come apart. I would put duck tape over the patch or gorilla tape to hold it in place. Again what do you have to lose.
Unread 20-01-2014, 07:58
AKA: Loyal
FRC #0716
Was just thinking. If you can get a pool patch to work then put a second larger one over the first one then the tape. Also always make your patch with rounded edges even if it is a long rip cut an oval shape.
Unread 20-01-2014, 08:07
AKA: Loyal
FRC #0716
And again one more. A hot glue gun. I have been successful using one to repair an air mattress. Cut patch out of vinyl put thru glue on the ball then put on the patch. Double it up if it looks like it will hold and then tape.
Good luck.
Unread 20-01-2014, 10:17
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
We had a hole with about an inch diameter.
Tried lots of stuff till it was fixed - what ended up working was a regular rubber pool patch, with some rubber glue (nothing special, the one that came in the KOP should do). Also - we put a piece of rubber on the inside of the hole, being somewhat larger than the hole itself - so the pressure inside isnt all put on the tear, but more spread...
We did it on week one, and the ball is ok ever since...
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 20-01-2014, 12:36
PiKman's Avatar
PiKman PiKman is offline
Once an engineer-always an engineer
AKA: Kevin Killian
FRC #1676 (Pascack PIoneers)
PiKman has a spectacular aura aboutPiKman has a spectacular aura aboutPiKman has a spectacular aura about
You can buy replacement bladders from Sportogo. $24.95 each plus shipping. I bought 3 replacement bladders as soon as we got our first damaged ball. This will put you back in business if you are having trouble getting official FIRST balls.
Kevin Killian
Coach
Team 1676, The Pascack πoneers
Proud to be sponsored by Dassault Falcon Jet, Inserra Supermarkets, BMW Group, BAE Systems, and Dimensional Communications
Unread 20-01-2014, 16:49
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Shoe goo, then duct tape, then another layer of shoe goo, has been working for us since day 2.
Unread 20-01-2014, 16:56
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Originally Posted by Jmulderig View Post
Has anyone repaired or know the best way to fix a popped ball....we had an oops. Yes we have looked at and seen all the google methods for exercise balls. We just want to know if anyone as actually performed the procedure.
You might try to use a pool of inflatable patch. Or a bicycle patch.
Unread 20-01-2014, 16:57
FF TSL: Frog Farce
We tried a bicycle patch, it didn't work.
