SerialPort viOpen error
I was trying to run the posted code in order to test out the serial port on our cRIO. The code faulted with a null pointer error due to the serial resource not being initialized and returning the error "VI_ERROR_RSRC_NFOUND in function viOpen"
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.SerialPort;
import edu.wpi.first.wpilibj.visa.VisaException;
public class RobotTemplate extends IterativeRobot {
public SerialPort serial;
public void robotInit() {
public void autonomousInit() {
public void autonomousPeriodic() {
public void teleopInit() {
try {
serial = new SerialPort(115200);
} catch (VisaException ex) {
System.out.println("Error to initialize serial port at 115200 baud " + ex.getMessage());
public void teleopPeriodic() {
try {
serial.print("test");
System.out.println(serial.read(1));
System.out.println("Error");
Re: SerialPort viOpen error
It may also be useful to check the following
We saw that bug, but the fix was attached in May and should have been rolled into the 2014 release, I would think. Plus this isn't the same error as that one. |
It's sporadic. SerialPort settings we use are 57600, 8, N, 1 The nav6 sends a stream of 30-40 bytes packets at about 20-50Hz rate, so a stream of bytes is arriving when the serial port is opened. [cRIO] edu.wpi.first.wpilibj.visa.VisaException: VI_ERROR_RSRC_NFOUND in function viOpen [cRIO] at edu.wpi.first.wpilibj.visa.Visa.assertCleanStatus( Visa.java:151) [cRIO] at edu.wpi.first.wpilibj.visa.Visa.viOpen(Visa.java:6 3) Here's a note on the error: "...there doesn't seem to be any consistency with when the error occurs. Occasionally it would happen after a few times of sending new code to the robot and sometimes it would happen after I had just powered on the robot. I wasn't able to find anything that seemed to be a specific trigger. I was typically able to fix it by leaving the robot powered off for a period of time and then powering it back on." [Side Note: If possible, if the Java SerialPort class is being modified, can the setReadBufferSize() method please be made public?] |
