Re: 2014 Vision Code
Looking at it more...I think processing on the cRIO would be easier. We're only using Vision for Autonomous, then we're planning on disabling vision.
Whichever way you decide to go, it is helpful to share data between DS and robot. The tutorial touches on this, and I've participated in a few other CD threads that go deeper. If those don't answer your questions, please ask.
Greg McKaskle |
As for sending data from the DS back to the robot, you can usually just use NetworkTables to send the data. NI's code and RoboRealm both have easy NetworkTables integration built-in. (Not sure about OpenCV, haven't tried it.) |
Thank you all for the help! We'll be doing some major testing to find the best route to go with and I'll come back with some questions if needed.
Thanks again! |
That all depends on the rate and complexity of the processing. You could probably get away with processing 1 image per match this year which shouldn't cause any problems at all running on the cRIO.
Depending on your auton routine of choice, I suppose. We're going to try for more complex autonomous routine this year, so we'll need as much flexibility in the vision as we can get.
#7
The LV example code for finding a game ball is takes two passes. While it would run on the cRIO, the robot and potentially the ball are both moving. I would think it would be hard to accomplish this without a DS or additional processor. The field targets seem pretty easy to do on the cRIO or any of the other approaches. By the way, "easy-vision" is still vision -- it's all relative.
Greg McKaskle |
