Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 01-19-2014, 12:59 PM
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
30A breakers for motor controllers?
Can anyone verify that there's no rule against running a victor-driven mini-cim on a 30A breaker circuit? The mini-cim is ~19A.
Thanks.
Unread 01-19-2014, 01:13 PM
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: 30A breakers for motor controllers?
The table in R46 does indeed allow this, but any reason as to why you're not running it off a 40A breaker? I assume you're not out of 40A slots on the PDB.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 01-19-2014, 01:45 PM
VEI Dude's Avatar
Mentor 4024, 4013
Yep... we'll most likely be out of 40A slots.
Thanks.
Unread 01-20-2014, 07:30 AM
Breakers are sized for the wire they feed. If you choose a smaller gauge wire then you may use a smaller breaker.
Unread 01-20-2014, 12:50 PM
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I thought we could use the larger gauge wire with a smaller breaker. We have been using 10 gauge for the 40 amp. This is left over from when 10 gauge was required.
The rules (R47) specifiy a minimum wire size per breaker size.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 01-20-2014, 01:23 PM
Andy,
Yes you can, the wire size minimum is listed by the breaker feeding that branch. i.e. a 40 amp breaker can be used with #12 wire but I recommend #10 for CIM motors. The wire size is chosen for safety and voltage drop from the NEC handbook for open frame DC wiring. If #14 wire was used with the 40 amp breaker, it is possible to heat the wire to the point at which the insulation fails. #12 wire on the other hand may get warm but not to the point at which a failure would occur. A dead short of course, would be protected by the breaker. At 100 amps, the #12 drops ~0.2 volts per foot. In a typical robot wiring job I would expect to lose almost a volt at the motor input during starting and heavy loading with a fully charged battery.
Unread 02-04-2014, 03:47 PM
hiddenhobbit hiddenhobbit is offline
FRC #1389
hiddenhobbit is an unknown quantity at this point
Can we use CIMs from the 30A? Or any motor controller for that matter?
Thanks!
Unread 02-04-2014, 04:11 PM
Isn't it the other way around?
If you choose a smaller gauge wire then you must use a smaller breaker.
Or maybe it's the ambiguity of the phrase "smaller gauge wire"...
