Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 20-01-2014, 13:59
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
What you've learned about your Cube 3D Printer
I saw the thread about the Makerbot Replicator 2 and figured there should be a separate one for the Cube 3D printer.
We have both types and so far I have had a much better experience with the MakerBot Replicator (it is a more expensive machine after all). I wanted to list out a couple of things that I have learned about the Cube so far.
  • The filament likes to be incredibly picky. We have a blue cartridge that refuses to be recognized by the machine. I current have an email out to 3D systems to find a solution on this one.
  • We have another blue cartridge that is recognized by the Cube but the flywheel/stepper motor continually strips the filament for some reason I have yet to figure out. I took the cover off of the print jet and to ensure there was not any filament dried on the gear/flywheel that was causing this and I am still seeing the issue.
  • I plan on running with the cover off of the print jet from now on, as it allows me to see when the filament is getting stripped.
  • The cartridge that came with the Cube (Neon Green) has filament tangled on the inside so you cannot actually pull any filament out, therefore the machine will not either.
  • When it works, the Cube can print some really cool stuff with the space it has. So far we have printed a very sturdy L bracket, two of the Rooks that it comes with, a minion from Despicable Me and a couple of keychains the students have designed.
  • With all of the issues we've had using the cartridge we are really looking at going with this idea: http://www.thingiverse.com/thing:76083
Has anyone else encountered issues or had some really cool successes?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 20-01-2014, 14:07
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: What you've learned about your Cube 3D Printer
I've found with our cube that due to the 3-point leveling system, leveling the bed can be very problematic.
We've also found that the printer seems to print very close to the melting point of the filament, because we've run into issues with parts cooling too fast and peeling off the print bed (even when using the provided glue).
Consequently, we've discovered that our build space may be too cold to operate the cube effectively without some kind of enclosure to regulate the temperature (we're considering building an enclosure out of polycarbonate to address this issue).
And finally, we've found that our cube seems to over-extrude the final (top) layers a bit, causing a rough top surface.
We actually printed this part but have yet to use it (still on our first cartridge), it looks like it will work ok, however positioning the part in the cube software is a bit of a pain because the author created it on a strange angle.
Unread 20-01-2014, 14:11
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
That was actually the first big thing we printed after the rook. We started noticing by the 2nd print job that the prints would fail after 20 minutes or so. Nothing was jamming the print head, but it soon became apparent that the cartridges themselves were constantly jamming, regardless of the type of plastic or color. We actually had to rotate in shifts to constantly babysit the printer while making this bracket on Saturday (5+ hour print, btw). It's been an otherwise great printer, but it is completely and utterly impractical for a team to have to constantly tug extra filament out of the cartridge. We're really excited to see how it will perform with this modification. Plus there's the small fact that the generic filament costs ~1/5 the cost per kg of a proprietary cartridge from 3DS.
Having said all that, I would still probably pick this printer again from FIRST Choice at the 300 point price level (which we did). 600 would have been way too much for the hassle. Don't spend money on this printer without knowing what you're getting into. It does work, but it is not remotely as plug-and-play as claimed.
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 20-01-2014, 14:25
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
I've read that they've updated the firmware so it keeps track of how much filament and will stop reading the cartridge chip after it is used up.
In all honesty while it's not in the "spirit of FIRST" we will probably end up selling ours. I already own a 300$ Makibox A6 printer that can do ABS and PLA with the same performance as the cube.
We would rather sell it for 1000$ buy a second Makibox for 300$ and use the 700$ to buy filament at 1/10th of the price.
It's really a shame that 3D systems isn't selling the filament at cost to FIRST teams.
2016: FRC 865 Mentor
Unread 20-01-2014, 14:28
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
We tried printing over USB to ours after activating it, and it told us to hit the "link printer" but we could not find the link printer button anywhere. We tried putting the included flash drive into the printer, and it showed no print files on it.
We were able to update the firmware on it, but that did not help.
Unread 21-01-2014, 22:24
shawnliner shawnliner is offline
FRC #3753 (BulahBots)
shawnliner is an unknown quantity at this point
It doesn't print via usb cable. Only from the flash drive and over wifi.
Make sure the files you are saving to the flash drive are .cube files.
Hope this helps.
Shawn Liner
Coach
Team 3753
When I learn, I win. If I can win too, that's gravy.
Unread 21-01-2014, 23:38
AustinH's Avatar
Has anyone had any luck using blue painters tape on the glass print bed? I heard suggestions to use that over the provided "glue".
Unread 22-01-2014, 09:44
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Our CAD students have been using ours more than anybody else, according to them the process is export from your CAD software of choice as a *.stl file, run the cubify software to create the *.cube file, and then place it on the flashdrive or print over wifi.
No issues so far using the included glue and our prints have been done in the shop which is one of the colder rooms in the school or at someones home since the school asked us to not leave it running unattended overnight.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 22-01-2014, 10:47
cbale2000's Avatar
AKA: Chris Bale
The glue seems to work fine for us, so long as the room temperature isn't too cold, so we haven't had to try the painters tape method.
You can downgrade the firmware to avoid the issue.
Doesn't the Makibox have a smaller build space than the cube? I looked at the Makibox myself when I was considering 3D printers, but I always thought it looked too small to do anything useful with, and the slack in the extruder positioning system made me worry about consistency.
Personally, if we were to sell our Cube, I think we would probably go with something like a 3rd Gen Solidoodle printer for the bigger build space.
Unread 23-01-2014, 08:59
Oak1477 Oak1477 is offline
FRC #1477
Oak1477 is an unknown quantity at this point
So our team got the cube and one of the first things we printed was that adaptor for cheaper plastic from thingiverse. It is for the gen 1 cube not the gen 2 so it did not fit. We had to make a custom one. Also make sure you have enough of that glue stuff down if not it can peel of the coating on the print bed. Also we had an issue were the bed was too high so we were jamming the extruder. Makes sure the bed never touches the extruder or it will not work.
Unread 23-01-2014, 12:33
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
I have found that letting the Cubestick dry causes the plastic from sticking to the bed. I have been applying one coat, letting it dry, then applying a second coat and starting the print while it is still wet/sticky.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 31-01-2014, 00:05
JACulpIII JACulpIII is offline
FRC #3389
JACulpIII is an unknown quantity at this point
I have been using ours with some filament I bought with personal money to figure it out. The team has access to a school commercial 3d printer for build stuff.
Here's what I've found so far...
If there's not much overhang PLA will print really nice most times, if it doesn't jam up inside the cartridge.
ABS doesn't print very well if there's alot of surface area as the ABS shrinks as it cools and lifts badly, getting the glue down just right helps some but I tend to have 3 fails for every useable success with the ABS filament I bought.
There doesn't seem to be a difference between solid and strong, has anyone else noticed this?
I was able to print an interesting planetary bearing that printed as one piece but turns correctly, the stars were in alignment as this one printed first try in ABS.
If we had to pay real cash for it I would have suggested we return it, for 300 FIRST Choice points it's ok, at least we can print give-aways and such with it.
James Culp
Programming Mentor
Team 3389
RoboSpectrum
Unread 31-01-2014, 01:16
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
While a decent machine that we traded 300 FC credits for - I would not spend my school budget on one.
It is a great teaching tool - but not when you are trying to show a video.
It sounds like a NES - an NES that is out of control!
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 31-01-2014, 12:02
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
Ours stopped reading a usb stick a couple days in but we messaged support and they're getting a new one shipped to us. I can't say much about the prints but their support us very fast and easy to work with.
Unread 31-01-2014, 22:17
DonRotolo's Avatar
Back to humble
FRC #0832
In general it prints OK, but definitely has a heat issue when printing thin and small areas, like the tip of a pyramid. It seems the heat can't escape the print fast enough if the area is too small.
Other than the setup, it's been plug & play for us.
The extruder does dribble out some filament as it heats up, and that gob of goo will ruin the print before it finishes the raft, so we've been using an index card to knock most of it off before the print starts.
Solid was definitely more solid than Strong.I would estimate they are 70% and 90% infill, respectively.
IF I had paid full retail for the Cube I'd be upset, but for the price and what it is, it's OK.
